Hi, anyone ever get this problem on asus x45u rev 2.1, this mb (motheboard) get on when plug in charger and 3-5 second get off and then on again just always like that continous. Please help me thankss
Asus X45U on off repeatly helpp
Re: Asus X45U on off repeatly helpp
Originally posted by mon2 View PostIs it stable with using only a charged battery?
Do you see video when it is on ?Attached Files
What are voltage readings on each pin of the battery connector?
Locate the battery connector and there will be nearby mosfets for:
Battery mosfet that will turn on during battery only mode.
High and low side mosfets to charge the battery pack using the 19v external power adapter feed.
What charger IC is on your board? Likely the TI 'BQ' charger series? Share the full markings of this IC for a review.
do you have a thermal camera? check, if something gets hot rapidly. it could mean anything: bad i/o-chip, broken bios, bad pwm controller, bad cpu/gpu, short on sub rail, logic failures and so on... take a look at all important rails, like mcplslg123 said, especially pwrgood and enable pins.
boardview attached, you need open board view and the fz-keyAttached Files
Does it make sense to probe charging circuit when battery is being charged/discharged perfectly?
From the details of the charger IC markings we will have a better idea of which logic is onboard since the schematic is in the witness protection program. Common to Asus.
The charger is most likely the BenchmarQ (TI) series but do post the top side markings / pics. Then we can review against reference datasheets or other schematics that feature this controller.
Update:
1) Found the repair guide and assorted BV files for this logic board.
2) The charger IC onboard is the BQ24725. Datasheet is attached.
The logic board will have a similar schematic to the one that is attached.
So this logic board will be fitted with 2 x DCin N-channel mosfets; high & low side battery charge N-channel mosfets; battery pass-through mosfets.
Which version is your logic board ?Last edited by mon2; 11-27-2022, 11:29 AM.
