Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools
Old 06-28-2022, 09:03 AM   #881
dmill89
City & State: Harrisburg, PA
My Country: USA
Line Voltage: 120VAC 60Hz
Default Re: Post your system.......
The first time I've bought a new (rather than referb/business off-lease) laptop in over a decade, but I figured I'd need to get something with Windows 11 eventually (eventually it will probably be my main laptop, but for now I'll be using it alongside my Dell Precision M4800 as I'm not ready to go "all-in" on Windows 11 yet) and MicroCenter had a heck of a deal on these ($599).
HP Victus 15-fb0121nr:
-CPU: AMD Ryzen 5 5600H
-GPU: Nvidia GeForce GTX1650
-SSD: 512GB NVMe
-RAM: 16GB (upgraded from the 8GB it came with) DDR4 3200MHz
-Display 15.6" 1920X1080 144hz refresh
-OS: Windows 11 Home (will likely be upgraded to Pro)
Build quality and serviceability (7 Philips screws to remove the bottom panel and then you have access to pretty much everything) are decent for a current production laptop. It is mostly plastic but has aluminum reinforcements and feel fairly solid (not quite mobile workstation solid, but better than many consumer laptops), and has a LiPo battery (like just about everything these days), but is fairly easy to replace if needed (remove the bottom cover, then it is 4 Philips screws and a connector, at least HP didn't glue it into the case or use "specialty" screws like some manufactures are doing).
dmill89 is offline   Reply With Quote
Old 06-28-2022, 09:41 AM   #882
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
Hell of a GPU for a laptop. What's the battery life like?
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 06-28-2022, 10:06 AM   #883
dmill89
My Country: USA
Quote:
8-10 hrs. with "general usage" (web browsing, MS office, etc., it has switchable graphics so under "light" usage it will use the integrated RX Vega 7 graphics rather than the nVidia card, and even the integrated graphics are more powerful than the dedicated K2100M in my Precision M4800), but it will suck the battery down in 2-3 hrs. with graphically intense tasks (gaming or video editing). Overall not too bad considering my Precision M4800 with an I7-4910mq and Nvidia Quadro K2100M will suck down its 97 Wh battery in 2-3 hrs. just browsing the web and barely lasts an hour doing graphically intense tasks.
Laptops have definitely improved substantially over the last few years in efficiency (which is good since hot-swappable batteries are all but extinct), and the last couple gens of intel/AMD CPUs have finally gotten significant performance improvements as well since being all but stagnant for 5+ years. The "mid-range" ryzen 5 5600H scores 17,192 on passmark, vs. the "high-end" (for the time) I7-4910mq in my M4800 only scoring 6,195 (and even the I7-4790 in my desktop only scoring 7,237).
Old 06-28-2022, 01:01 PM   #884
lti
lti's Avatar
City & State: Windsor, Colorado
I'm a: Hobbyist Tech
I'm surprised by how low the prices are on gaming laptops now. That one actually looks nice. I get about the same battery life on my current laptop with a 90Whr battery.
I don't think I posted my current laptop here, except for the other thread when I considered returning it and getting something else before being unable to find anything better. It's a Lenovo ThinkPad P53.
CPU: Core i7-9750H
RAM: 16GB
GPU: Nvidia Quadro T1000
Storage: 1TB Western Digital SN730 SSD
Display: 1920x1080 60Hz HDR400 (HDR off because it's bugged in Windows and the brightness keeps dropping to the minimum)
Aside from the poor cooling (and Lenovo setting both CPU power limits to 90W, basically keeping the CPU in its short-term boost clock) and the strangely limited audio hardware (48kHz sample rate and no TRRS jack for headsets) that I've talked about before, the GPU has an older NVENC version that is missing some features and is equivalent in quality and speed to Intel Quick Sync in the CPU.
lti is online now   Reply With Quote
Old 07-11-2022, 05:51 AM   #885
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
I'm a: Knowledge Seeker
9th gen and earlier has a critical CSME vulnerability that requires a UEFI-BIOS update. (remote-code-execution) I had to get rid of my 9th-gen, because there was no UEFI-BIOS update with the new CSME found. The Intel CSME-checking utility failed it.
__________________
ASRock B550 PG Velocita
Ryzen 7 "Vermeer" 5800X
32 GB G.Skill Trident Z Neo F4-3600C18D-32GTZN
eVGA Supernova G3 750W
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo
RJARRRPCGP is offline   Reply With Quote
Old 07-11-2022, 12:46 PM   #886
lti
lti's Avatar
I remember that, and this laptop was patched pretty quickly (as expected for a business laptop).
Another thing is how annoying the Lenovo Vantage software is. It's nice to get updates if there's a major problem or security vulnerability, but it pushes a registry cleaner and might be what tried to force-install the wrong audio driver (causing a blue screen) once. None of the updates have set more reasonable CPU power limits yet, and it probably doesn't matter since setting them to what I think are Intel's defaults (55W PL1 and 45W PL2) still makes it go over 90°C under load.
Old 07-17-2022, 08:33 PM   #887
dmill89
My Country: USA
Thanks to some Prime Day deals I did an upgrade on my main desktop:
CPU: AMD Ryzen 9 5900X
Motherboard: MSI MPG X570 GAMING PLUS
RAM: Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200
Video Card: Nvidia GeForce GTX 1070 (re-used from old system, waiting for the RTX 40xx cards to come out before I upgrade)
SSD: WD BLACK SN850 NVMe 2TB
HDD: Toshiba X300 4TB (7200 rpm)
CPU Cooler: Thermalright BA120
PSU: PC Power & Cooling Silencer 910W (re-used from old system)
Case: Cooler Master HAF-932 (re-used from old system)
DVD-RW Drive: Samsung SuperWriteMaster SH-S203N (re-used from old system)
Blu-Ray-RW: LG SuperMulti-Blue BH12LS38 (re-used from old system)
Misc: Memory Card Reader (re-used from old system)
OS: Windows 10 Pro
Old 08-03-2022, 09:34 PM   #888
RJARRRPCGP
My Country: USA
The AMD Linux rig:
MSI B450 Tomahawk
Ryzen 7 3700X (Matisse) (3rd-gen Ryzen)
Sapphire Nitro+ Radeon RX 6600 XT
AData XPG SX 6000 Pro 1 TB SSD
Corsair TX-M 850W PSU
Old 08-07-2022, 11:56 PM   #889
RJARRRPCGP
My Country: USA
Ubuntu Jammy was installed on August 3, 2022. Looking good the last time I checked again yesterday. (4 days later)
Old 08-17-2022, 08:38 AM   #890
dragonmas
City & State: Sarasota Fl
My Country: USA
Latest build
dragonmas is offline   Reply With Quote
Old 08-17-2022, 03:24 PM   #891
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Nowhere, Texas
My Country: USA
Line Voltage: 120/2/[email protected]
I'm a: Hardcore Geek
Quote:
Originally Posted by dragonmas View Post
Latest build
Nice looking build. Is that an AMD Wraith Prism cooler?
__________________
Windows 11? Bug-infested mess.
SpinRite 6.1 - Too Little Too Late
Permanently Retired Systems:
Kooky and Kool Systems
- Gateway 80486-DX2/50 - Operational/WIP
- Athlon 64 Retro Gaming System - Out of service until further notice
TechGeek is offline   Reply With Quote
Old 08-26-2022, 07:46 PM   #892
dragos2009
City & State: Craiova
My Country: Romania
Line Voltage: 220VAC 50Hz
OS: Windows 10 Pro
i hope you did enable ram xmp profile cause in the last pic it shows 2133mhz and that is really slow and bottlenecking for that ryzen 5900x
dragos2009 is offline   Reply With Quote
Old 08-26-2022, 10:32 PM   #893
dmill89
My Country: USA
Quote:
Yes I did, that pic is from the initial boot (note the incorrect date/time).
Overall I'm pretty satisfied with the performance.
Old 09-07-2022, 06:24 AM   #894
brownharris561
City & State: Washington
Macbook Pro - Ultimate powerful machine :P
brownharris561 is offline   Reply With Quote
Old 10-17-2022, 07:25 AM   #895
wolfie_24
City & State: santa cruz
My Country: argentina
Smile Re: Post your system.......
Hi fellows.
Primary setup
CPU..........................Ryzen 9 5700X
Mother......................MSI X570A Pro
RAM.........................Corsair Veangance RGB 2x16G DDR4
Disk(s):
>One NVME Kingston M2 1TB in Turbo PCIE4
>other NVME Kingston M2 1TB in PCIE3
>One SSD Kingston A400 1TB SATA 6Gb
Video........................MSI RX 6700XT Gaming Pro 12G
Thermal
>Watercooling gamemax ARGB Infinity 240mm
>plus 4 coolers Gamemax ARGB 120mm (2 over radiator >and 2 in the bottom working push pull)
>and one more in the back of cabinet.
Thermal compunds
>Gelid GC Extreme
>Maxtor CTG8
>Arctic-12
>Valor Odin
>Gelid GP Extreme
PSU........................... Namakaze 1600W Plus Gold
Cabinet...................... XFX Keiko GC-04B ARGB
Monitor...................... Viewsonic 24" full HD
Keyboard an mouse
>Microsoft Wireless Comfort Keyboard
>Wireless Optical Mouse
(Yesssss... very old and very comfortable too!!!)
Gaming
>Saitek Pro Flight Yoke and system
>Saitek Pro Rudder Pedals
>Saitek Mad Catz Cyborg PC Flight Stick
Stabilizer.................... CVR 3500W - 180 to 250V input to 220 Output modified with digital display for input voltage, and output Volts and Amps
Thanks for watching and Greetings from the south of Argentina!
wolfie_24 is offline   Reply With Quote
Old 11-21-2022, 03:01 PM   #896
Dan81
SNES-powered
Dan81's Avatar
City & State: Bacau
My Country: Romania
Line Voltage: 230VAC 50Hz
Got my own taste of a 1156 "gamer" machine:
i7 860 @ 2.8GHz
Gigabyte P55A-UD3
Inter-Tech 750W PSU (XHY/Xilence OEM'd, has 2x 6pin PCI-E)
CM Hyper H412R cooler
Radeon HD7870 2GB
1TB Seagate ST31000524AS
2x2GB DDR3 RAM
Win 10 Enterprise LTSC 1809
__________________
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Dan81 is online now   Reply With Quote
Old 11-21-2022, 06:24 PM   #897
XTA
City & State: NSW
My Country: Australia
Line Voltage: 240VAC 50Hz
Main PC:
CPU: Ryzen 9 5900X
RAM: 64GB DDR4 Corsair Vengeance RGB Pro 2 x 32GB
GPU: MSI Ventus RTX 2070
Case: Laserhive kit Modded mATX PowerMac G5
Motherboard: Gigabtye B550M Aorus Pro AX
Storage: 1x 1TB Crucial M.2, 1x 500GB WD Blue M.2, 1x 120GB Kingston SSD, 1x 500GB Crucial SSD
Operating System: Windows 11, Debian 11 Bullseye.
Power Supply: Corsair RM 850x
Cooler: DeepCool Castle 240EX
Repair Setup PC:
CPU: Intel Core i7 6700k
RAM: 16GB HyperX DDR4
Storage: 240GB SSD, 2TB HDD
Motherboard: MSI B150M Bazooka Plus
Power Supply: Cooler Master G650M
Case: Cougar Spike mATX
Cooler: Deepcool Alta 9 CPU Cooler (Not much but it gets the job done)
No need for a GPU in this system, Built out of parts I had laying around.
XTA is offline   Reply With Quote
Old 11-28-2022, 04:33 PM   #898
dmill89
My Country: USA
Video Card: Nvidia GeForce RTX 3070
OS: Windows 10 Pro
The GPU fairy showed up (ok not really, but RTX 3070s were marked down to $450 on black Friday), the rest of the specs on my desktop remain the same.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
