Dell Microsoft autopilot issue
    Hello ,
    Any one come across this logon screen error while installing windows
    Popularly know as “Microsoft autopilot”
    How can this be by passed as this take many information from the laptop
    Like serial , mac , ssd , sku etc ..
    Re: Dell Microsoft autopilot issue
    Same issue. Did you try to change the service tag?
      Bios file .Bios file .Bios file .Bios file .Bios file .Bios file .Bios file .
      Become a Badcaps supporter
      Thanks to all supporters.
        Here is the file with MDM, notice that Microsoft use the following information to determine if a device is managed or not. Changing some of them can get rid of MDM, for sure only one or two of them not work.
        DiskSerialNumber
        TpmVersion
        EkPubHash
        MacAddress
        ProductKeyId
        SmbiosSystemFamily
        SmbiosSystemManufacturer
        SmbiosSystemProductName
        SmbiosSystemSerialNumber
        SmbiosUuid
          DiskSerialNumber
          TpmVersion
          EkPubHash
          MacAddress
          ProductKeyId
          SmbiosSystemFamily
          SmbiosUuid
          Try
            my laptop. lock MDM. ?
            how to fix? every body can help. !
            all donations are welcome,
            >>>>> click on this link to donate via PayPal. <<<<<
              Try changing the window key in bios
                some one can help me Dell xps 9510 Dell Microsoft autopilot
                  Try
                    Just wondering if anybody has been successful with this?
                    Because afaik, atleast on thinkpad, you would need a CPU replacement.
                      Say again? CPU replacement to get rid of autopilot? Just change SN for lenovo and reinstall. Windows Autopilot uses the OEM so changing win key in bios and reinstall from scratch will do the trick. when is reaching "internet connection" just click on "i don't have internet" and setup without internet.
                      Sometimes if you setup in bios secure boot to setup mode instead of user mode and erase secure boot keys will also work.
                        DiskSerialNumber
                        TpmVersion
                        EkPubHash
                        MacAddress
                        ProductKeyId
                        SmbiosSystemFamily
                        SmbiosUuid
                        it uses all of these when you install intune or azure ad in windows and create a profile to remote manage the computer At installation it uses only OEM (part of) as win key or/and SN. from my experience, changing win key embedded in bios and reinstall OS from scratch erasing all partition from ssd/hdd will allow you to skip registration to a domain having option to not connect to internet (I don't have internet) and setting up user without internet connection.
                        Newer, creating USB installation for win with rufus last release and checking few options will allow you to skip checking win key from bios and at install will ask you to type a win key or skip by clicking on "I don't have a key".
                          Originally posted by hoaca388 View Post
                          Try
                          Not work bios
                            Not work bios
                            Does it not boot or is the autopilot still on?
                              not boot. no display
                                Test And Coments,
                                you must flash the bios and load windows from a flash drive
                                  Originally posted by aldopc View Post
                                  Test And Coments,
                                  hi. thank you for your help. but i gave laptop to customer
                                    Ofcourse I know how to bypass it but that is not how you remove it. There's a difference.
                                    Meaning that I wouldn't care about it but a client will.
                                    An easier method to bypass is just installing Windows Home version since that will not even check for autopilot.
                                      Please help me to get rid of this popup
                                        try this, i'm not sure. this bios just deleted some data. test and feedback result .
