IC Marking Codes and Datasheets #2
    Re: IC Marking Codes and Datasheets #2
    Richtek Rt8243bzqw
      Thank you bro
        IC mark 3G=xx Richtek RT6575A
        IC mark 3F=xx Richtek RT6575B
          Thank you
            I need help identifying this IC, it's from an Intel NUC NUC6CAYB, attached are 2 photos of the IC and 1 photo of a normal motherboard found on the Internet.
            I think the marking reads RG5WK or R65WK and the other photo reads RG5VC or R65VC I think
              So I think I found it, but I'm not sure: https://www.ebay.com/itm/334488627756
              Is it SYX198CQNC ? What does this IC do? The NUC is flashing RAM problem.
                Appears to be a dual mosfet from Silergy. Replace it from a donor board or from AliExpress.
                US $4.59 15%OFF | 10pcs SYX198BQNC SYX198B SYX198 (RF4BJ RF3CG RF2BN RF...) QFN-6
                https://a.aliexpress.com/_mNTwNHw
                Do share the full markings with the vendor before purchasing.
                  Can anyone help me. I have a switching voltage regulator on a DELL Latitude 5430 for 5v power. I can't identify the IC code
                    What is logic board # of this Dell? LA-**** markings. This part is likely from Silergy.
                      I apologize for the slow response. DELL 5430 board number is LA-L591P
                        DNExxx = SYD370CTMC
                        Pinout equivalent with this ic on here
                        https://www.badcaps.net/forum/showpo...81&postcount=3
                          Originally posted by martha februarini View Post
                          DNExxx = SYD370CTMC
                          Thank you very much. This is exactly what I was looking for.
                            Re: tps51123 equivalent
                            who makes IC that resids where 3.3/5V buck is located. it has markings 11 FL 60. I don't have luck finding it.
                              Post a pic of the part that shows the topside markings.
                                not able to take picture, using mag glass.
                                first row :11 FL
                                second row: 607
                                no other markings nothings. this is on HP 2570P motherboard part number 6050A2483801-MB-A02
                                  A diode marked as PJ8017, but I can't find it on Aliexpress.
                                  I need to find the correct part number.
                                    I think I found it, using a similar schematic, it seems to be P4SMAFJ20A since they have IV as their marking.
                                    It seems to be a Transient Voltage Suppressor (TVS) diode, can I replace it with a Schottky Diode?
                                      Can you share more details on which board contains this diode ? PJ may be Panjit (Taiwan).
                                        It's the G7BF, there's no schematic for it, I think it's similar to DAG7BFMB8D0.
                                          someone help me figur out this one please
                                          it is in CPU power circute, probably dual mosfet
                                          Acer Chromebook intel Gold CPU
                                          Model Name: CB515-1W
                                          MB: DA0ZBTMBAD0
