I am having problems with Gigabyte Gaming G1 1080 that is visible in device manager (with an error). GPU-Z identifies it partially (has a name of the card, card ID, but lists revision as FF). Other info (voltages, frequency, etc.) spills from the remaining GPU that's used as primary display.
- Mats crashes with a segmentation fault.
- If I boot with the card as the only card I get no picture.
- All voltages are present
I swapped the BIOS chip, tried different BIOS revisions, but no luck. Is there any chance there's fault in something else than the GPU core? Any tips for other tests I can try?
Thank you so much.
Thank you so much.
