Yamaha RX-V373 not powering up
    I've a Yamaha RX-V373 which does not power up, only main relay clicks and then falls back, already checked the following:
    - DIAG or Advanced menu does not work
    - All relevant sub voltages are available (5-7-12V)
    - According to the SM,IC's 268-262 and 261 should give 1.3V, 1.2V and 3.3V but at all I measure around 7V at pin 1 (so output voltage is equal to input voltage 7V)
    - As a try I swapped IC-262 for a new one but still measuring 7V output.
    - As these 1.3,1.2 and 3.3V voltages are feeding processors (a.o. uP and DSP) I assume this is the reason why the unit doesn't start up due to the voltage errors. For now I'm stuck where to look further and am hoping that someone had the same issue and can provide some tips/guidelines. Any help is welcome.
    Re: Yamaha RX-V373 not powering up
    I suspect you are using the wrong ground to check the voltage, use the DG digital ground for these voltages. I suspect the unit is going into protection due to a faulty audio output ic.
      Hi RJ, ok I've measured between pins 1(+) and 4(ground) of the IC's but still have around 6V in stead of the 1.2V and 1.3V what it should be....
      To your suspicion of faulty output IC:
      1) I've disconnected the AC connections from the transformator to the board that feeds the driver amps, so based on that at least it should start up with display but it doesn't
      2) In case one of the driver amps is bad I still should be able to get into the DIAG menu which then would give me the DC-PRT xxx message. Or do you have an experience with a faulty driver IC that caused the amp to be dead completely? Appreciate your feedback!
        What are you measuring? You need to measure not between 1 and 4 pins, but between 3 and 4 pins.
          Tnx, see the mistake I made, measuring between 3-4 of the IC's provides the correct voltages. Also on the UPc IC voltages are correct so it may be assumed that the start up circuit works ok. Will check if UPc sents out start PWR RY 3.2V.
          Also checked the 0.22 ohm protection resistors of the driver ic's but they all measure ok, so any reason to assume that the issue could be one of the IC's? Again I would expect in case of faulty end stage that at least unit would power up and then shuts of due to protection and you still would be able to enter DIAG menu, which is not the case. Display doesn't light up in any circumstance..tnx again for your support.
            Try this - connect to the network (220v) hold down the "TONE CONTROL" and "STRAGHT" buttons and press "POWER"
              More - Unplug the receiver
              Hold down the "TONE CONTROL" and "INFO" buttons
              Then connect the receiver to the network
              And then press the "Power" button and hold all 3 buttons for at least 3 seconds.
                Hi lotas, that's what I tried already > getting in DIAG menu (tone control + straight + power) or Advanced Setup Menu (tone control + info and connect to power outlet). In both cases receiver does not start, only main power relais comes up and falls back again, so it doesn't look that protection circuit is activated, unit simply doesn't power up.
                I checked the 3.2V PWR RY at CB151 once power button has been pushed and that's there but should be as the main relais is being activated shortly......
                  In cases like this, I suspect amp shortage and I just start measuring the final transistors for shorts. Maybe unplug the amp section?!
                    Hi Tibimakai, as mentioned earlier in the thread I disconnected the AC connection from transformer that feeds end stage but no result but anyway I'm one step futher: allthough nothing pointed at the driver stage based on measurements I decided to swap the STK433-330 and now the unit starts, at least I hear the driver stage relais coming up and I can switch off the unit again. But the display doesn't light up at all so I guess there was a double failure in the unit: both STK IC and display have an issue. Will now measure the display section to see where it goes wrong. Again many thanks for all ideas and tips! Cheers, Rob
                      Update: voltages around display all ok, funny thing: display was set to -3 so nothing to see.. put it back to 0 and voila... only things still missing now: 1) sound, nothing coming through all inputs nor USB 2) Advanced Setup Menu: when entering the advanced setup menu the display only shows trash, nothing readable, strange enough the DIAG menu works fine. Already looked for latest firmware for this unit but it seems that Yamaha never has released another FW version than implemented during manufacturing....to be continued...
                        Do you need firmware?
                          Hi Iotas, if you would have FW for this one I would certainly try this. Just let me know how you want to sent it to me. Tnx!
                            See private messages.
                              Tnx Iotas for the FW,I think the issue with the failing sound and seems to be the flatcable between frontpanel and HDMI board, it looks damaged and when I move it, sound is there, now need to find an AWM 20798 17 pin but they look hard to find. Maybe I've a donor receiver in stock, need to check. Will keep you guys updated...
                                Good afternoon,
                                I saw your post mentioning that you would have Firmware for the Yamaha Receiver RX-V373 device. Mine is not transmitting 4k because I don't have hdcp 2.2. I would try to update the firmware to solve this problem. Would you help me? Thanks.
