A1932 820-01521-A PP3v3_UPC Short
    Hi all got a head scratcher
    A1932 came in booting just with no keyboard or trackpad, I found missing PP3v3_G3S rail on J6700 lead me to what I thought was a short around U3700 "wifi ic" so i removed R5510 and injected voltage 0.5v not seeing anything under thermal camera i stupidly increased voltage to around 2v 3A and still nothing..
    Now i have no boot and short on both CC PP3v3_UPC_XA_LDO 8.4Ω & PP3v3_UPC_XB_LDO 2.5Ω, PPDCIN_G3H is 0V regardless of what port i plug into and my voltages are as follows
    Port 1 - U3200 5v - 0.148A
    Port 2 - U3100 5v - 0.153A
    Nether cycles so my best guess atm is both CD32's are dead? any assistance would be greatly appreciated!
    Prior to repair I warned my customer of known cpu issues and made a backup so i don't feel to bad just tilted i made things worse.
    Re: A1932 820-01521-A PP3v3_UPC Short
    I've Ordered two new CD3215C00 ic's just waiting on the postman.
    However, before I install them, is there anything I should be looking at before I power up?
    Pretty sure I still have a short @ pin 1 R5510, but if after CC32 replacement it boots I'm handing it straight back and referring them to someone like Paul Daniels, I'm just worried I caused more damage then what i found :/
    Also if anyone has any tips on voltages or basic steps/post formatting I may have missed or not posted that would help with diagnostics I'm very open to hearing you out and learning!
      What is the voltage to ground of PP3v3_G3H_RTC?
      Check this webpage about your case:
      https://repair.wiki/w/A1932_2018_-_2019_MacBook_Air
        PP3v3_G3H_RTC = 3.291V
        I replaced both the CC32 ic's and now its back to 20v and seems like its charging and somewhat booting as i have fanspin again but no image
        I checked its not in dfu mode then ran the thermal cam over the board again and seen U8210 is hot so i lifted it and i still have a short on pin 5/6 PP3v3_G3S
        I'll lift R5510 again and see its its really on the PP3v3_G3S_WLANBT line & read through the repair wiki and report back.
        Also has anyone got any good suggestions for a new lab power supply ? i need something that can do 5-10A @ 0.5v-1v as my current supply is limited to 3A and only gets there above 2V..
          We use the TS-30A Short Killer product from Phone fix on AliExpress. It can spike out 30A and we dial up 0v8 on the voltage. Works well to locate shorted caps.
            Ordered one thank you very much!
            Lifted R5110, Short still on pin 1. after some thermal imaging @ low voltage limited current i didn't see anything so suspected U3700, Lifted U3700 WIFI/BT IC and my short from PP3v3_G3S is now gone however its still not booting though i get 20v and what seems to be normal booting/charging current.
            all voltages around U7800 appear normal without cycling and as per the wiki these rails check out
            PP5v_G3S - 5v & high resistance 10K+
            PP3v3_G3S - 3.3v & high resistance 10K+
            PP1v8_G3S - 1.8v & high resistance 10K+
            PP3v_G3H - 3v & high resistance 10K+
            then i get to PPBUS_G3H
            PPBUS_G3H - 9.7v 53K+ this is so very wrong.. U7000?
              Remove the fuse on PPBUS_G3H.
              Power up again. What is the voltage to ground of PPBUS_G3H from the producer side (ISL)?
                Sorry that reading was with battery connected and it must have been alittle flat as its up to 12v now and 12.65v without battery connected and 12.65V with a know good battery.
