Hi, I am trying to save my old monitor once I was so proud of. I hope there are still some people around with experience.
Symptoms: overbrightness and visible retrace lines. When full white image is displayed, the monitors shuts off with flashing yellow.
I have read previous threads and posts with similar issue, but none of the solutions can be applied to my monitor. According to them I need to suspect the G2 voltage as the issue.
I attached the page of the A board schematic. In my case the G2 voltage supply coming from the flyback transformer is supposed to be 1kV and I measured 938V with my multimeter. The exact applied G2 voltage is controlled by the MCU through the RGB preamplifier. Additionally there is a delay circuit that pulls this voltage slightly lower initially which effect vanish after half an hour or so. And here comes the confusion. The schematic says the G2 voltage is supposed to be 615 V (as seen on Q1 collector). I also happen to have the training manual for the CPD-G400, (which is basically the same monitor with multiple VGA inputs) and on the G2 control page (attached) it says that cold G2 voltage is supposed to be 660 V. After half an hour it increases to 667 V. Now, in my case the cold voltage is 674 V and after half an hour it goes to 685 V. It is much higher than 615V, but quite close to 667V. Which one may be right? The G2 control voltage (coming from the RGB preamplifier) is measured as 2.39V which is almost exactly 2.38V as specified. All in all, the G2 related circuits seem to work fine, I am not even sure that the voltage is too high.
Any ideas? And is it possible to check the exact reason for malfunction when I switch to aging mode (full white screen)?
(Of course I checked the power supply lines as well. I have all voltages, though all of them is slightly lower. Like 200V -> 197V, 80V -> 77V, 12V -> 11.7V etc.)
