UMAX 14wa - switched charger polarity need identify ic
    have this UMAX 14wa that switched charger polarity. i found some bad ic and i need to identify it.
    Mark on it is
    R9CSC
    it is voltage regulator
    Re: UMAX 14wa - switched charger polarity need identify ic
    Mark on it is
    R9CSC
    post more info and pictures. Need to see the footprint and number of pins, package type, and if there`s any manufacturer logo besides the marking code
      no other marking
        no other marking
        I only find this part from silergy
        SY8388B3RHC
          thanks. from here it looks like it.
          Silergy marking codes
          https://www.forum.diacom.az/viewtopic.php?p=680
            One of those lists at that forum is a copy of ours https://www.badcaps.net/forum/showpo...1&postcount=12 .The R9***/SY8388B3RHC has been posted at the russian vlab forums in their silergy thread,and at the 4pda forum, i havn`t added it to our list there`s no pictures or datasheet available (only to silergy customers) ,so there`s no way to confirm it. Overview https://www.silergy.com/zh/productsview/SY8388B3RHC
            The SY8388B3RHC can be found on Teclast F15 and Chuwi CoreBookXPRO motherboards,there`s no full schematics available for either of them but i found a BOM and motherboard outline for the Chuwi
            https://www.badcaps.net/forum/showthread.php?p=1183457
              Nope, I found it from vlab. But still i can't find seller who sell it
                Sharing the attached.
                  only one on ali. 15e for 2pieces
                    Found in the NM-C771 schematic as well https://www.badcaps.net/forum/showthread.php?t=110962
                      Ask any high rated vendor on AliExpress that sells silergy parts for help. They will run across the street and buy it for you in Shenzhen.
