How sensitive are WLCSP packages to damage?
The photo is of the Audio/Headphone CODEC on a Macbook a2485 820-02100 motherboard. The motherboard doesn't power on, possibly because this chip is holding the PP1V8_AWAKE rail down. It's not shorted, just the 1.8v rail going into it only comes up to about 0.7v, then resets. Which I think is stopping the machine powering up fully. There are a few other chips on the same rail but they all look fine.
Anyway, if anyone has an opinion on WLCSP chips I would like to hear it. I've used Intel CPUs with chips/scratches in the die without problems. I read that on flip chips the circuit isn't near the top/edges of the die. Is that also the case for WLCSP chips?
Just as a warning. I damaged the chip while trying to reinstall the motherboard. The a2442 and a2485 macbooks have a load of push fit connectors on stiff ribbon cables for the USB ports, speakers and mag-safe connectors. These catch on the motherboard and seems they can damage the components on the the motherboard quite easily. Probably a good idea to tape them out of the way when removing or installing the motherboard on these Macbooks...
