HP ProBook 650 G8 BIOS Admin Password
    Greetings all, could you please assist with the unlocking of this 256 Bits BINS
    HP ProBook 650 G8 i5-11th gen
    Board Number: DA0X8QMB8E0 REV:E Model: X8Q
    Please find attached the BIN's
    Re: HP ProBook 650 G8 BIOS Admin Password
    Here's your unlocked files. Just try to program the EC Unlocked, if the password still present program the SPI Unlocked too.
    all donations are welcome,
      Thank you, I will give the feedback.
        Wow it worked, I'm in I wish I know how to do it so that I also help others when they post for help... You are a Genius.
        I followed the instructions, I only reprogrammed EC immediately when it boots I saw an endpoint error I knew it worked.
        Now is unlocked I can make changes to BIOS
        Thank you, if there is any topic about how to do it on BAD CAPS please share it so that I learn..
          This post will give you a general idea about bios password, you can search more in this forum and you will find a lot.
          https://www.badcaps.net/forum/showpo...42&postcount=4
            hi, pls help unlock this bios
              Become a Badcaps supporter
              Thanks to all supporters.​
                Originally posted by Vesko356 View Post
                thanks for quick reply, it worked
                  You're welcome.
                  Please consider donation in support of the "Bios Requests" section of the forum.
                    hp probook 650 g8
                    the bios on my unit is locked. i do however have full acess to a windows 10 installation on the machine. is it possible for me to remove the password in the bios using any method? thanks for any assistance and guidance.
                      Re: hp probook 650 g8
                      I think flashing the bios chip will resolve your issue!
                        bios ok but CODE 10
                        lan not detected . CAN YOU HELP ME? pls!!
                          Originally posted by duong.160694@gmail.com View Post
                          bios ok but CODE 10
                          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                            seri number 5CD123B40L
                            board number DA0X8QMB8E0
                            model X8Q
                            pls!
                              model X8Q
                              pls!
                              TRY flash both main and ec...
                                Hi, I need BIOS admin password removal on the same model as the first guy.
                                Model: HP 650 G8
                                MBDA0X8QMB8E0 REV E
                                I leave the EC and SPI backup below. Thank you!
                                  [QUOTE=Radipta;1289061]Hi, I need BIOS admin password removal on the same model as the first guy.
                                  Model: HP 650 G8
                                  MBDA0X8QMB8E0 REV E
                                  I leave the EC and SPI backup below. Thank you![/
                                  Flash only EC chip try it than replay
                                    Model: HP 650 G8
                                    MBDA0X8QMB8E0 REV E
                                      [QUOTE=farouk_1994;1289063]
                                      Model: HP 650 G8
                                      MBDA0X8QMB8E0 REV E
                                      Thank you it's working, and sorry sir SMDFlea. I will follow the rules next time.
                                        HELLO MY friends
                                        I WANNA REMOVE PASSWORD HP PROBOOK 650 G8
                                        EC FILE
