#141 |
Slow Learner
City & State: Lancashire UK
![]() Shade Engineer- So why ask in this "teaching" / Guide thread !!!? start your own - read the stickies and post the pictures.
Please upload pictures using attachment function when ask for help on the repair http://www.badcaps.net/forum/showthread.php?t=39740 |
#142 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
![]() Toshiba 32av502R fix.
http://www.badcaps.net/forum/showthr...02R#post471219
Never stop learning Basic LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#143 |
![]() SONY KDL_S4100 FIRMWARE V1.115
http://www.badcaps.net/forum/showpos...0&postcount=27 |
#144 |
![]() Sony KDL-52V150 Firmware and instructions.
#145 |
![]() KDL-40S41 00, KDL-46S4100, and KDL-52S4100 firmware installtion instructions and firmware:
Side notes: http://www.badcaps.net/forum/showthr...d=1#post525059 |
#146 |
![]() Samsung LNxxA630 series with same bad caps (C102, C131 should be changed at the same time) as LNxxA550 series.
http://www.badcaps.net/forum/showthr...208#post525208 |
#147 |
![]() Sony KDL 40v5810 firmware:
http://www.badcaps.net/forum/showpos...4&postcount=10 http://www.badcaps.net/forum/showthr...284#post525284 Last edited by budm; 01-28-2015 at 10:53 AM.. |
#148 |
![]() PANASONIC cap for C102:
http://www.badcaps.net/forum/showpos...&postcount=129 |
#149 |
![]() Kester Alloy temperature chart.
Temperature conversion chart. |
#150 |
![]() NASA Workmanship standards.
http://workmanship.nasa.gov/lib/insp.../frameset.html http://workmanship.nasa.gov/lib/insp.../frameset.html http://workmanship.nasa.gov/lib/insp.../frameset.html Last edited by budm; 02-23-2015 at 12:17 PM.. |
#151 |
![]() Vizio GV42L Turns On then Off: Thanks to AVGEEK
http://www.badcaps.net/forum/showthr...42L#post491523 |
#152 |
City & State: Caledon Ontario
My Country: Canada
Line Voltage: 120VAC 60Hz
![]() Wow this thread keeps expanding, what a wealth of knowledge! Stopped by and filled up my library...
Thank you again Budm for your continuing efforts(: |
#153 |
![]() Toshiba 32AV502R, 37AV502R with unstable 5VSTBY (blinking green power LED, and the STBY power supply uses VIPER27 IC).
Replace D200 (1N914/4148) which feed the OV signal to pin 3 of the IC. http://www.badcaps.net/forum/showthr...125#post535125 |
#154 |
![]() Learning more about electrolytics caps.
#155 |
![]() SAMSUNG notes on bad MUR diode.
http://www.badcaps.net/forum/showpos...1&postcount=36 |
#156 |
![]() CXA3809 IC (PFC, ACD, SMPS)
Working Voltages: http://www.badcaps.net/forum/showpos...4&postcount=20 BEFORE WITH BAD IC6301 ------ STBY | POWER ON C6325 340V 340V C6117 7.75V 13.45V C6118 8.05V 13.89V Vcc @ CXA3809m 7.77V (stby) 13.48V (on) Pin2 (mode)@ CXA3809m** 0.3mV (stby) -24.3mV (on) pin3 (AC_detin) @ CXA3809m** 0.601V (stby) 0.576 (drops) T-Con VCC, REG 12V, UNREG 12V, all 0v or close enough stby or on. AFTER IC6301 SONY A3809 REPLACED ------ STBY | POWER ON C6325 339V 394V C6117 12.45V 14.02V C6118 12.41V 14.34V Vcc @ CXA3809m 12.44V (stby) 14.04V (on) Pin2 (mode)@ CXA3809m** 12.38V (stby) 93.8mV (on) pin3 (AC_detin) @ CXA3809m** 5.36V (meter on DC) 1.83V (meter on AC) |
#157 |
![]() Simple LED driver IC.
#158 |
![]() About SLA batteries:
http://www.badcaps.net/forum/showpos...3&postcount=16 |
#159 |
City & State: Slobozia/iALOMITA
My Country: Romania
![]() how to test LED backlight?
thanks! |
#160 |
Thread Tools | |
Display Modes | |
