I have an Antec TruePower 380p PSU that I had repurposed from a Sonata case. It had been working fine on a server in the loft using the Wake-on-LAN feature regularly until a couple of recent power outages where the power became very unstable - going on/off very quickly. There is now no output whatsoever from the PSU & fan isn't working. There was a pop when I attempted to turn it on.
Upon examination, it appears that voltage isn't getting very far so I believe the immediate issue is within the first stage. There is a green component that I am not familiar with. It has '005 10' written on it. Is it a MOV? Does anybody have an idea of the spec? There is a hairline crack that goes around the side of it and a burn mark on the rear. So I'm guessing this means it is toast. The DMM measures 22Ohm.
Here are some photos...
Front of component
Rear of component
Any help in suggesting a replacement MOV appreciated - assuming I'm correct that it is a MOV!
Daniel
Front of component
Rear of component
Daniel
