Hello!
I was given this Vizio because it would freeze up after a few minutes of operation. There were no obvious burns marks or failures. When I was checking the power supply - I slipped & shorted it (tiny crackle & spark) at one of the 12 volt pins - now the entire board is dead & has NO standby voltage @ the connector to the main board.
The fuse at the power input is reading good - the main caps are reading in the 160's & all the diodes read good except one (D9103 - pictured) - but it only reads bad in circuit - I pulled it & it tests o.k.
There doesn't seem to be getting power to the cold side of the board anymore...
Any help, direction or what/where to test would be greatly appreciated - Mike
[IMG][/IMG]
[IMG][/IMG]
