Hello my lovely fellows, I have a question for you, how do you confirm if the cpu it self it shorted to ground?
Sometimes I come across situations where the cpu power rail including gfx will beep when checking capacitors both sides, ground and positive on the beeping mode and give me a value of 000 ~ 002 (beeping mode).
I uplifted the pwm cpu output coil from the board, the beep stops on the other side but the cpu ceramic caps are still beeping on both sides with the value of 000 ~ 002 on the beeping mode. Anyway the board got the on board cpu and I don't have reballing tools
Thank you
Thank you
