Fake KZE 680uf 16v?
    Fake KZE 680uf 16v?
    I bit on a lot of 25 of these. Judging by the sellers excellent feedback (99.9) I just assume these are just old inventory. Thoughts? What type of vent/bung should I see on an authentic one?
    https://www.ebay.com/itm/680uF-16V-N...5/401011429492
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Fake KZE 680uf 16v?
    Hmm..., the one picture in the listing isn't much to go by, but the text seems a little "off".
    Here's a pic of the same cap I bought from a known reputable source (Digikey) for comparison:
      Thanks for the pics, I'll compare once I receive them. Yeah the text is a little light compared to yours. The bung looks correct and they don't have vent pics. Hopefully the vent is mercedes style and not an X. I got some fake Sanyo's with an X and not a K vent. I pretty much knew those were going to be fake.
      Ryzen 3600x
      FX-8802 Iron
        Suspect that a jagged print is just as bad!
        When it looks like a game with aliasing!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          Let us know what you find.
          The seller is based off of Potomac, MD, which isn't that far from me.
          Would be a good deal if they are genuine.
          I don't think the text can be used too much to tell if they are genuine or not. It does look a bit "faded", or at least not as precise as on known genuine KZE's I've gotten before. But then again, I've also seen the text vary slightly between different cap batches made in different years on a lot of the Japanese caps.
          And at least from the picture the seller provided, the bungs look genuine. If they were flat and not going beyond the can, I'd definitely flag them as counterfeit. But on these, the bung appears extruded like it should be on good KZE caps.
          *EDIT*
          I looked through the seller's entire e-cap inventory, and I saw a lot of old/retired/discontinued cap series like KME and SME (from UCC), along with PF and PL (Nichicon).
          Here are a few other listings of interest:
          https://www.ebay.com/itm/2200uF-16V-.../161859188724?
          https://www.ebay.com/itm/1000uF-16V-.../161859345192?
          https://www.ebay.com/itm/6800uF-6-3V.../161859157688?
          Particularly, have a look at the second image in those listings.
          A lot of these look like old stock. For example, the Nichicon PL caps in the last link appear to have a date code of year 2000. So those are already 20 year old caps, more or less.
          And with that said, I think there is actually a good chance those KZEs you bought may actually turn out to be genuine, but may be slightly older stock. In any case, that's still not a bad deal. For the very old caps, though, I imagine they would need reforming after all of those years in storage. Probably still OK to use, but I'd just be a little more careful with them at this age.
            Seem legit to me, sorry for the crap photo's, I used my tablet instead of my phone because it was all I had at the time.
            This said 665uf - vloss 1.6%
            Ryzen 3600x
            FX-8802 Iron
              close up pics of the bung please! usually thats a dead giveaway.
                I'll get some nice clear shots later tonight. I went home for lunch and they were in the mailbox but I left my phone in the car so I had to take pics with my horrible tablet. The Bungs looked pretty much like the genuine ones linked above. I'll still post pics later on
                PICS!
                Ryzen 3600x
                FX-8802 Iron
                  Link to pics listed on previous post. Won't let me edit it anymore to move it here. Link is to imgur album
                  Ryzen 3600x
                  FX-8802 Iron
                    It looks legit to me - there are several different plants as well as contract production from Korea Chemicon and other affiliates. Japanese production tends to have thin vents and a shiny aluminium finish, while contract production tends to have wider vents and a slightly matt aluminium finish. If it measures within spec on capacitance and ESR, it's likely to be legit.
                      Also notice in the eBay AD there is a date on the pictured shipping box: 27/11/2005
                      This matches the "5 N F (3)" UCC date code of the capacitor well (translates to: 2005 - November - 6 - (Plant 3).
                      So in other words I would reform these caps before use to be on the safe side.
                        How would one "reform" these?
                        Ryzen 3600x
                        FX-8802 Iron
                          Follow the link (in the word reform) in my previous post.
                            Sweet, so basically if I have a bench supply I should be good? How many can I do at a time with a single 1K 1/4 watt resistor?
                            Is this acceptable? Found a beefy 1.5K resistor
                            Ryzen 3600x
                            FX-8802 Iron
                              As many as you like - at least for low voltage caps like these anyways. Now, if dealing with caps where the reform voltage has to be so high as to cause significant dissipation over the series resistor, then you have to take that into account too.
                              But since that's not the case here, you can do even all 25 caps at once, if you like. The only downside of using a single 1 KOhm (or 1.5 KOhm resistor in your case) is that the reforming will take longer before the caps reach full voltage. For this reason, I prefer to put no more than a few caps per resistor (or ideally one cap per resistor.) But in any case, the reforming will work.
                              I'd say leave them connected like that for a few hours, and they should be good to use again.
                              https://i.imgur.com/81fU7Ku.png
                              That will do.
                              Yup.
                              Looks like the seller is selling leftover production or overstock NOS capacitors.
                              For $7 total for 25 slightly older/NOS caps, that's not a bad deal (comes out to about 28 cents per cap.)
