Transformer for HP zr24w
    Re: Transformer for HP zr24w
    Originally posted by douardda View Post
    A TNY279 only cost a dollar or 2, so just replace it and you'll see if it is indeed the cause of your failure (I also bet it is).
    Yes, it was it. All works fine after replacing of TNY279.
    Thank U gratefully. U really helped me to save ZR24w. Your story of repair was the only that I had found.
    Is that a common problem fo PSUs? I have the old TFT-TV with the same problem.
      Good to hear you got it working.
      No, usually those offline SMPS ICs are not a common problem. Most of the time it's the caps that go bad in LCD monitors, followed by the occasional rectifier... and of course, backlight issues (bad CCFLs, inverter transformers, inverter transistors, etc.). The offline SMPS ICs rarely go, but I suppose there could be some specific PSU models that have these particular issues. Now that there are two of you who encountered this particular issue with this monitor, it is quite possible many other zr24w monitors are like that.
        Hi all. I just repaired my defective HP ZR24w by replacing the TNY279. Seems quite common with these displays. In my case, the TNY279 had actually exploded, ripping of the top part. Thank you for describing problem and solution so well.
          hp zr 24w
          exploded
            Please help,
            i my case... TNY dead and rezistor R961 same and I dont know value or type ("burn"). Thanks for reply.
              Originally posted by Paxancz View Post
              Please help,
              Show us the pictures of YOUR whole board, and the pictures of this R961 location.
                Originally posted by johnatan View Post
                can you please send me marking of IC I907?
                thnx
                i have the same issue with johnatan. blown IC 1907. what part number is that? thanks!
                  Originally posted by balobi View Post
                  i have the same issue with johnatan. Blown ic 1907. What part number is that? Thanks!
                  ic 1907 - tny279pn
                    Do you have schematics of this
                      I would appreciate if a schematic for this psu would be uploaded
                        https://whatever.sdfa3.org/hp-zr24w-psu-repair.html
                          Originally posted by gunnish View Post
                          I measured the power supply, 5V is ok, but 12 V and 19 V reads 0 V, just plain dead.
                          So i measured the caps and diodes, they are fine. So then I looked at one of the transformers, the resistance between the conductors on the secondary is 0.2 ohm, so short circuit.
                          How do I find a replacement transformer, I really don't understand the markings.
                          I know this is an old post, but I'm looking for the schematics of the zr24w power supply, if someone can help me it will be very appreciated.
