elitebook 840 G1 remove CIRA authentication
    Hello
    I have the elitebook 840 G1
    CNU407C42V
    It give the CIRA authentication.
    How can i remove this.
    I already flash the main Bios whit no succes
    Regards chris
    Last edited by SMDFlea; 04-17-2022, 01:41 PM. Reason: elitebook 840 G1 remove CIRA authentication
    Re: elitebook 840 G1 remove CIRA authentication
    Originally posted by rickjansen01 View Post
    Hello
    CNU407C42V
    Regards chris
    search the site for a bios model of the motherboard and clean the ME region.
      Hello Peste
      Can you clean the file for me
      I try but Bios hang and 5 time led.
      Regards Chris
        Hello Peste
        Regards Chris
        Is that your original bios backup .
          Hello SMDFlea
          Yes this is the original one
          Best regards Chris
            elitebook 840 G1
            Become a Badcaps supporter
            Thanks to all supporters.
              Hello Hoaca388
              I still Have the CIRA authentication.
              Regards Chris
                Hello Hoaca388
                Regards Chris
                try this file
                  Hello Hoaca388
                  Stil CIRA.
                  Can it be the ec bios that is doing this.
                  Best regards Chris
                    Hello Hoaca388
                    Stil CIRA.
                    Best regards Chris
                    Try disabling AMT in the bios settings. https://en.wikipedia.org/wiki/Client..._Remote_Access
                      Hello SMDflea
                      I did that but stil CIRA.
                      I try a lot but still CIRA
                      That is why I ask for the ec bios.
                      Best regards Chris
                        Hello SMDflea
                        Best regards Chris
                        you should also have a 2mb chip on the motherboard, post the contents of the chip..post the bios of the I / O chip ..
                          Hello Peste
                          Do you mean the 25q16dv
                          Best regards chris
                            Here the file
                              Hello Peste
                              I change the main and ec but still CIRA
                              Do you mean the i/o from the keybord socket
                              If so do you have the pin layout for me
                              Best regards Chris
                                Hello Peste
                                Best regards Chris
                                if you rewrote both bios chips and it was not deleted try the I / O chip..yes it is the chip from the keybord socket ... I don't have the pin configuration ... maybe someone else will help you with this ... if you succeed, post the content. .
                                  Hello
                                  CNU407C42V
                                  Regards chris
                                  Send me photo CIRA authentication.Where show in bios or Windows?
                                    Hello
                                    The problem is solft
                                    It turns out that the keyboard is broken
                                    and thats why he turn F3 on and that is CIRA.
                                    Thanks you al for the support
                                    Best regards Chris
                                      Hello
                                      Best regards Chris
                                      OMG. : nutkick:: nutkick:
