Connect40 Loewe TV manual / advice please
    Hi all
    This set seems to power up , with LED at front changing to GREEN , but no picture , or backlight , plus cannot set TV back to standby .
    Suspecting main board issue .
    Powered the backlights independently & they light up ok .
    Disconnected HDD & powered , with same results .
    Checked supplies at all the buck regulator outputs on main board & again seem ok .
    Anyone have experience working on this model .
    Re: Connect40 Loewe TV manual / advice please
    On lifting the main board , suspect i have discovered the issue .
    There's quite a chunky silicon thermal pad the sits between the chassi & underside of BGA CPU chip .
    Pad had leaked out quite badly & i suspect damaged CPU .
    Washed the main board with flux cleaner , then IPA , but didn't help.
    Now i require a board .
    Can anyone help ?
      Turn of event it seems .
      Allowed the board cool down fully , as it had been sitting on pre-heater , then powered again .
      To my delight set powered ,with half picture good & the other noise .
      Pressured the LVDS processing chip & picture corrected itself .
      Time for a re-ball me thinks .
        So need to reflow chips.
          The LVDS BGA chip , yes .
          I tend to re-ball rather than re-flow , as it's more reliable .
            I would at least reflow main chip also
              Thanks , did consider that also , but will see how the LVDS chip re-ball goes .
                Stencil arrived , re-balled LVDS chip & TV now running on test .
                No audio via HDMI 1 for some reason , but not really concerned , as customer has another 3 ports to play with .
                  Interesting, have not seen a tv with an actual sata hard drive.
                    Hi yes , Loewe have to be different .
                    Set also seemed to be shutting down by itself, but to be fair i had been running it without heat sinks on LVDS & CPU chips , albeit with a fan pointed at them .
                    Refreshed thermal paste & fitted the sprung loaded heat sinks back & now seems to be behaving .
                    May potentially need to also re-ball CPU at some point therefore will order a stencil for that as well .
