PS48 Bose sub & head unit schematic / advice please.
    PS48 is model for sub & where i suspect issue lies .
    CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
    Can't seem to measure any voltages at secondary side of PSU within SUB unit .
    Re: PS48 Bose sub & head unit schematic / advice please.
    Yep ,primary side requires a rebuild .
    First on the list Q101 & Q102 ( ST Electronics P9NB50FP ) . Both S/C , which doesn't surprise me considering the amount of glue across their respective pins that had turned a dark brown colour & no doubt become conductive .
      Also replace the following .
      U101 , ST Electronics L6598D
      R101 , 10R
      R103 , 10R
        C119 ( 470NF ) has a leaky resistance reading of 10K
          D150 , marked KJJN9 , which is in fact BAV70 .
          Contains two diodes with a common cathode .
          One of them measuring leaky & become a 2 way street .
            Q104 , marked K3NN7 , which is an MMBT3906 has a low reading of 45R at collector / emitter junction .
              Q103 , marked K72 L7 , O/C .
              Only mentioned on parts list & schematic as being an N-CH-FET .
              Spotted a thread on another forum stating that it's type 2N7002
                Also stated on thread found that the opto's can go leaky .
                Not taking any chances therefore replaced U102 & U103 , both type CNY17F-1
                  WOW ,what a mission .
                  All working & on test .
