It's from a Yamaha keyboard, a PSR-S900:
I couldn't find any obvious shorts to ground anywhere. The two
100 Ohm resistors are in parallel in-circuit, and measure a good
50 ohms together.
The secondary coil (pin 7 to 10), measured 368 Ohms.....is this
normal?
There appears to be a healthy +4VDC going into it, but
I don't know how to test the high AC voltage on the
output (isn't it in the 1000s of Volts?), and I don't have
a similar LCD display to test it with.
Would it be safe to use a cracked laptop screen
I have lying around, and hook the inverter cable to it,
and see if the back lights up? Or I remember some of you have
used a neon light bulb to test inverters?
Sorry if this is the wrong place to post this, but I figured
most TVs these days use CCFLs with inverters, so you
guys would be best to ask.
Thanks for any help.....
50 ohms together.
normal?
