need bios dump dell latitude 5420 (cpu 11th)
    Re: need bios dump dell latitude 5420 (cpu 11th)
    hi, i have a latitude 5420 locked with password in bios. i have tried some suggestions with removing bios IC and patching with RegionME from a cleared bios dump but did not work.
    wondering if anyone can give me a hand with this bios lock. i have the original unedited dump. the board it came from is LA-k491P
    any help would be greatly appreciated.
      Originally posted by brandonac9 View Post
      hi, i have a latitude 5420 locked with password in bios. I have tried some suggestions with removing bios ic and patching with regionme from a cleared bios dump but did not work.
      Wondering if anyone can give me a hand with this bios lock. I have the original unedited dump. The board it came from is la-k491p
      Become a Badcaps supporter
      Thanks to all supporters.​
        thank you very much Vesko356 for your assistance.
        i will program it into the ic now and come back with feedback.
        also very curious about what more needs to be done other then the RegionMe that needed to be patched. any chance theres a guide for this or a tutorial that i can read in hopes to gain more knowledge?
          Hello, there is a dell 5420 11th gen i5 with locked bios (board model GDF40 LA-K491P Rev 2.0), i've tried a dump belongs to someone else and it worked except that there's no nvme detection, when i went back to my original backed-up dump it didn't work, i think it's corrupted or something, could someone help to check and unlock please ?
          here's my original dump
            Hello, need help unlocking...
              Originally posted by onizzbox View Post
              Great! Enjoy the laptop!
              please unlock for me
                  Originally posted by Vesko356 View Post
                  bios it work.thanks my friend.
                  you can share autopatch for me
                    Compare the two files with the Hex editor and note the locations of the differences. Only 3 points.
                      it 3
                        need this file clear me pls late display
                          Have you tried cleaning the ME firmware,there are some guides you can follow - https://www.badcaps.net/forum/showpo...41&postcount=3
                            pls clear my bios password file attached same model
                              https://www.badcaps.net/forum/showpo...4&postcount=70
                                Try :
                                  Try :
                                  Not edited properly, needs more correction.
                                    Ok, try one more.
                                      Ok, try one more.
                                      @sundarkanini , do not use file at #107. Thanks !
                                      Mod, please delete attached file at #107. Thanks!
                                        Much better attempt, #108 file is now correct.
