RCUnlocker
Re: RCUnlocker
Ignored that, no file uploaded to test with
Check if you got the unlocked file anyway because that error happens after patching.Last edited by RethoricalCheese; 10-24-2021, 01:54 AM.
Re: RCUnlocker
Originally posted by RethoricalCheese View PostThis is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
Unlocking
HP - ProBook, EliteBook, ZBook (including 32MB models)
Chromebooks from all various manufacturers
Apple - everything older than T2
More to come...
Information display (helps to verify file integrity)
HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
Custom logo removal
Usage: Drag and drop .bin file to .exe file.
In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
You may ask for feature requests, I'll see what I can do.
-- hello there, the BIOS can be updated by holding down the windows key + B when powering on the laptop... is there no way to take a bios dump without removing the chip.... then using RC unlocker tool to remove the bios passwords... then using the bios update tool to reflash the .bin file to remove the password? just a suggestion of course i knoew nothing in this area of expertise but wanted to know if it was possible or not many thanks kind regards!
Re: RCUnlocker
Originally posted by erzhan89 View PostHello, everyone.
I am looking for a bios dump from Probook 445R G6.
Re: RCUnlocker
Originally posted by bhatt View PostI download this software but its not working, how its work anyone reply me
https://www.badcaps.net/forum/showpo...15&postcount=1
Re: RCUnlocker
Originally posted by onelook View PostWhich files did you unlock with the software? Also both 32mb and 16mb bin files or just the 16mb bin file?
Here are my dumped files
ThanksLast edited by SMDFlea; 04-01-2023, 01:44 PM.
Re: RCUnlocker
I think I got it.
For HP, you erase the NVRAM region (not entirely sure how this is detected)
For Chromebooks, you flip the devmode and enrollment bits (I guessed correctly!)
For Apple devices, you clear a 289 byte region starting with 0xAA557F00 (maybe HP works the same way - clear a XXX byte region starting with 0xYYYYYYYY)
Very cool
EDIT: Ah, yes. For HP, it wipes a region starting with a bunch of 0xFF and "NvramActiveRegn", and ending with [something I didn't bother to remember].
Sure would've been nice if you had uploaded this as a Python script instead of a PE executable, so I wouldn't have had to open up a Windows VM and copy a bunch of files back and forth to "reverse-engineer" this XPLast edited by unilock01; 11-19-2021, 09:01 AM.
