Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices > BIOS Requests ONLY!
Thread Tools Display Modes
Old 08-13-2020, 10:04 AM   #1
Knucklegrumble
City & State: North Carolina
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
Hello everyone!
In the past several weeks I've learned a lot from this forum and its community especially from all the folks who contributed to THIS thread
With some trial and error I was able to reliably patch BIOS dumps for SVP-locked Lenovo machines up to the 8th generation using the info, tools, and files provided on this forum. After some practice and positive feedback from users I helped I've noticed that, once learned, the process is fairly straightforward, so I've developed a small python script to automate it and allow everyone to patch their own binaries without having to ask for help and wait.
This is my way to give back to the community. Also I am lazy... lol.
DISCLAIMER
  1. THIS SCRIPT IS FREE AND IS INTENDED FOR EDUCATIONAL PURPOSES ONLY.
    You CAN download it, modify it, redistribute it, etc. I only ask that you DON'T sell it or try to make a profit from it, and that you please credit the authors for the time and work they put into it.
  2. I TAKE NO CREDIT FOR CREATING THE DXE DRIVERS OR ANY OF THE FILES THAT MAKE UP THE PATCH ITSELF.
    I've only developed the python script that automates the process and puts it all together.
  3. I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE, YOUR PETS, YOUR HOUSE, YOUR LIFE, AND THE SPACE-TIME CONTINUUM
    Making this kind of modifications is risky and might leave you with an unusable/broken machine.
    The script is not perfect by any means, and while I haven't bricked any hardware (yet) I can't promise that won't happen to you.
    USE IT AT YOUR OWN RISK.
With that out of the way, using it is pretty simple and it should work on both Windows and Linux as long as you have Python installed.
Just download the zip file and extract it. You'll get a folder named "lenovo_autopatcher" with the following content:
IMPORTANT: Before applying the patch make sure you verify that your original image is not corrupted by dumping 1 or 2 additional images from your bios chip and comparing them. The original dump is THE ONLY WAY to recover your machine if something goes wrong!
From command line use either autopatch.cmd (Windows) or autopatch.sh (Linux) as follows:
autopatch <your_bios_image.ext>
THAT'S IT!
The command will generate either your_bios_image_PATCHED.ext or your_bios_image_PATCHED_CLEAN.ext depending on the type of BIOS you are patching. The original dump will be left unchanged.
autopatch -h will output the help info for the command
autopatch --howto will output the following instructions on how to use the patched image:
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
[ NOTES ]
When booting the patched BIOS you might have to:
- Hold the anti-tamper switch down the whole time (use tape)
- Remove the hard disk or replace it with a locked one
Finally, I would be grateful if you could report any bugs, errors, problems, or general feedback in this thread so that I can make improvements to the script.
Thank you, and enjoy!
Knucklegrumble is offline   Reply With Quote
Old 08-13-2020, 11:43 AM   #2
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
Default Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
thanks, good job, i will look at this. Doesn't that correct the checksum?
Maxpower3 is offline   Reply With Quote
Old 08-13-2020, 12:13 PM   #3
Knucklegrumble
My Country: US
Quote:
If you mean after switching the DXE drivers, it uses UEFIReplace to inject them, so that takes care of rebuilding the binary image.
Now since you mention the checksum... Initially to verify that the image obtained using the autopatcher was the same as the one I'd manually patch I compared them using checksum and windiff but they never came up identical so I was concerned that the one generated through the script would not work. Turns out that when I patch a file manually using UEFITool I replace the 2 DXE drivers at the same time and let the program do it's thing in one pass. UEFIReplace however can only replace one driver at the time and it rebuilds the binary after each substitution. That somehow causes a few bytes to be different. I have tried replacing one driver at the time with UEFITool, save it reopen it and replace the other one and the resulting file is identical to the one generated by the autopatcher.
Old 08-13-2020, 12:37 PM   #4
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
If bios beeps at startup, the checksum is not corrected.
I had the problem here and followed this tutorial
But I failed to do a correct bios.
https://www.badcaps.net/forum/showth...=65996&page=11
https://www.insanelymac.com/forum/to...eps-on-lenovo/
Old 08-13-2020, 12:52 PM   #5
Knucklegrumble
My Country: US
Ahh I see... I do not modify the checksum of the patched bios so I am assuming it WILL beep 5x... That should not prevent it from going through the process though and reset the TPM. After that you have to reload the original bios anyway which will have the correct checksum.
Am I missing something?
Old 08-13-2020, 01:04 PM   #6
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
some machine does not work if not corrected, I think so
you have tried a lot of models already?
Old 08-13-2020, 01:28 PM   #7
Knucklegrumble
My Country: US
I've tried 8-10 different models between 4th gen and 8th gen. All reported working. It would be interesting to see what people report using the autopatcher.
Unfortunately I don't have that many SVP-locked Lenovo's on hand... lol
Old 08-13-2020, 01:39 PM   #8
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
yes I will test as soon as I have the opportunity too
Old 08-13-2020, 01:34 PM   #9
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
if you compare an x240 with an L470, you notice that there is a blue part in uefi tools. you need to correct checksum for work.
no need to patch each bios, the patched files are compatible in other machines. just need to create a library
on the last gen, it is written twice (see pics)
Old 08-13-2020, 01:48 PM   #10
Knucklegrumble
My Country: US
Do you mean that if you correct the checksum then the file is compatible with different machines other than the original one?
Old 08-13-2020, 02:20 PM   #11
Knucklegrumble
My Country: US
What's "List NOK with Patch files"?
Old 08-13-2020, 02:32 PM   #12
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
some model that doesn't work with just patched files.
It's been a long time since I looked at this, I don't remember very well
Old 08-13-2020, 02:42 PM   #13
Knucklegrumble
My Country: US
Right. The autopatcher has 2 steps. On the first pass it injects the patched DXE drivers. If the bios is from an older gen it ends there and its work is done. If it's a newer generation on the second pass it replaces parts of the NVRAM with clean ones and then it's done. I've patched some of the ones you have listed in NOK and they all reported working.
Old 08-13-2020, 02:47 PM   #14
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
ok my error is the NVRAM and not the checksum then
Old 08-13-2020, 02:50 PM   #15
Knucklegrumble
My Country: US
Yeah that's the part that took me the longest to figure out... I had to piece together a lot of posts on several threads and compare a lot of original and patched files to figure out what I was missing. Those parts cannot be patched with UEFITool and are only visible with UEFITool NE. They need to be modified with an hex editor. The script does it for you.
Old 08-13-2020, 03:01 PM   #16
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
Yes ok I saw the 2 VSS2 and FTW. Why patched EVSA, it is identical to orignal?
Old 08-13-2020, 03:17 PM   #17
Knucklegrumble
My Country: US
The EVSA was tricky...
Without patching that the laptop plays a little musical tone after boot and the screen stays black...
Old 08-13-2020, 04:19 PM   #18
Maxpower3
Maxpower3's Avatar
City & State: Paris
My Country: France
[QUOTE=Knucklegrumble;981236]The EVSA was tricky...
ok you clean OA3 and the rest ... nice job of comparison and research.
good news for the patch, it will be easier.
thank you
I made a patch nokey for translate file with key,
can I use your script to integrate it with maybe?
I had in the idea of ​​making a multi patch for bios with the different information to recover here
I manage with a few tools, but my level is limited
File Type: rar MxP Lenovo Translate NoKey Patcher.rar (211.8 KB, 322 views)
Old 08-13-2020, 05:20 PM   #19
Knucklegrumble
My Country: US
thank you
Sure you can! Hopefully we'll get some good reports from users. I have made a couple of changes to the script I'll post later on this thread. Unfortunately I can't edit my first l post though, so I'll just have to add it to another post...
Old 08-13-2020, 06:25 PM   #20
crowntoy99
City & State: kerala
My Country: india
I'm a: Student Tech
[QUOTE=Maxpower3;981258]
thank you
good jobe bro
crowntoy99 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
