Do I want Ripple Current high or low?
    I see this value varies within several 3300uf caps. Do you want that number low as possible? It's very high on polymer caps.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Do I want Ripple Current high or low?
    for capacitors, it refers to the maximum ripple current handling capacity before the capacitor goes kaput really fast. therefore, the higher the ripple current handling capacity rating, the better. there is no limit. aim for the sky. hope that clarifies it.
      So is there overhead with this rating? Like near a computer processor, if you replaced a capacitor with the same voltage and capacitance but went lower on ripple rating, would it be an issue? I assume it would be more of an issue in a power supply secondary side?
      Ryzen 3600x
      FX-8802 Iron
        Well, a MB has DC-DC converters on it, basically DC input power supplies. So impedance and ripple current ratings for the input and output capacitors matter.
        When you're talking about the decoupling capacitor networks for a processor, those can have current transients in the tens of amps at rates in the 100s of amps-per-microsecond. Narrowly speaking the electrolytic or polymer capacitors in the decoupling network need to be low impedance - low ESR and low ESL. But capacitors with low impedance generally have high ripple current ratings.
        PeteS in CA
          3300uF @ 10 V=Are you recapping an Asus socket 462 motherboard? (CPU runs off of +5V rail on Asus socket 462 motherboards) Or an early-one? (From the T-bird era)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          16 GB AData XPG Spectrix D41
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            some of them are rated at 100KHz and some are 120Hz, i don't know why they are not measured at the same frequency?
              It's an XBOX. Original caps were something like 2800(mArms) and the new ones I've been replacing are 2200 and 2500 (ZLQ and UHV). I've been going with 10v lately because space permits the slightly wider cap while getting a boost on the ripple current rating.
              Ryzen 3600x
              FX-8802 Iron
                Originally posted by jayjr1105 View Post
                It's an XBOX.
                My buddy, has an XBox version 1x.
                  It depends on the anticipated usage.
                  Modern low impedance and ultra-low impedance parts will be rated at 100KHz because the anticipated usage is power supply and DC-DC converter output capacitors. Switch frequencies vary, of course, but the datasheets typically have a graph that gives an idea of how a part's impedance varies with frequency.
                  120Hz rated parts tend to be general purpose or designed for bulk input capacitance for a power supply.
                  PeteS in CA
