LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • CornholioGSM
    • Feb 2014
    • 260
    • CZECH
    #181
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    1) download and install python (i have 3.8.5)
    2) download and unpack tool lenovo_autopatcher_0.2.zip to own folder
    3) make dump of bios image xxxx.bin, check twice if is dump correct
    4) put bios dump into autopatcher folder
    5) in autopatcher folder hold shift + press right mouse -> open command line window
    6) in CMD write "autopatch xxxx.bin" and wait for results
    *** if you got something like python error, then is simple solution - copy all files with bios dump from autopatcher folder to python folder root...for example
    C:\Users\vaio\AppData\Local\Programs\Python\Python38
    ...then again open Command line in this folder and again "autopatch xxxx.bin"
    tested on w7
    • danito
      • Jun 2016
      • 844
      • Romania
      #182
      For T540p SVC pass.
      please remove
      thx
      • CornholioGSM
        • Feb 2014
        • 260
        • CZECH
        #183
        Originally posted by danito
        For T540p SVC pass.
        please remove
        thx
        check this let me know
        • lapfix
          • Mar 2020
          • 2635
          • my workshop
          #184
          For T540p SVC pass.
          please remove
          thx
          Try
          • CornholioGSM
            • Feb 2014
            • 260
            • CZECH
            #185
            Originally posted by lapfix
            Try
            ...i was first
            • danito
              • Jun 2016
              • 844
              • Romania
              #186
              Originally posted by CornholioGSM
              ...i was first
              • lapfix
                • Mar 2020
                • 2635
                • my workshop
                #187
                ...i was first
                • Ivon
                  • Oct 2020
                  • 2
                  • United Kingdom
                  #188
                  It worked!! T440p.
                  Very pleased and enjoyed getting there in the end, as well as learning some things on the way. Also my grandson now has an upgraded (SSD & more memory) laptop which he needs for school.
                  Many thanks for knucklegrumble and all those that worked on and supported the solution.
                  • danito
                    • Jun 2016
                    • 844
                    • Romania
                    #189
                    it`s works thx
                    • danito
                      • Jun 2016
                      • 844
                      • Romania
                      #190
                      Yoga 3 bios spv pass
                      • Stangl
                        • Mar 2020
                        • 17
                        • Österreich
                        #191
                        tested on w7
                        Thank you!!! Now I get it. I have a Lenovo T540p but there are two bios chips, which one should I dump the 4Mb one or the 8Mb one or both?
                        • hani55
                          • 99
                          • morocco
                          #192
                          tested on w7
                          thank you so much
                          • hani55
                            • 99
                            • morocco
                            #193
                            Just download the soft , drug and drop your dump ,you get your file patched.
                            And alwways say thank to the owner.
                            if you have some trouble ,write it and someone gonna guide you
                            thanks brother
                            • CornholioGSM
                              • Feb 2014
                              • 260
                              • CZECH
                              #194
                              haya,
                              i have today unlocked 540p too...patch only 4mb...and better is desolder ic from mobo...and dont use asprogrammer (if you have ch341 etc).
                              Asprogrammer gives me always bad dump
                              ...after flash patched image inter into bios - it will ask for pw - write any pw, enter and then any id, spacebar , spacebar...and done....write original unpatched back and all is unlocked
                              • Stangl
                                • Mar 2020
                                • 17
                                • Österreich
                                #195
                                haya,
                                Ok,damn... I have a CH341A, this:
                                https://www.banggood.com/CH341A-24-2...r_warehouse=CN
                                which programmer do you recommend? Thanks for your assistance, your advice is very helpful.
                                • CornholioGSM
                                  • Feb 2014
                                  • 260
                                  • CZECH
                                  #196
                                  You can use HW CH341...but not with asprogrammer sw or classic ch341 sw
                                  ...by us is now night and i am not by my work laptop...i mean that i have read it correctly with modified Ch341 software...name like black edition v2.30 or 1.30...but i am not sure. Write me tomorrow PM and i will tell you more.
                                  ...but first test to read it desoldered
                                  I can upload this sw here but i am not sure if i can due forum rules
                                  • Trickiedickie
                                    • Aug 2020
                                    • 6
                                    @Stangl
                                    Download the Colibri programming software from here:
                                    https://elektrotanya.com/programmer_...wnload.html#dl
                                    • Bonzas
                                      • 468
                                      • Indonesia
                                      #198
                                      i tested with vpro processor not working,
                                      tested T450 i5 vpro, but on T450 without vpro working fine
                                      • Stangl
                                        • Mar 2020
                                        • 17
                                        • Österreich
                                        #199
                                        Originally posted by Trickiedickie
                                        @Stangl
                                        Thank you so much
                                        • black0hackers
                                          • Jul 2020
                                          • 365
                                          need patch for X1 carbon Gen5 - NM-B141
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            Hi everyone,
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
