Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 07-08-2018, 09:18 AM   #1
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default Has anyone used this module before Voltage Regulator DC 4-40V To DC1.25-36V 8A 200W
Here is a link to one of them
https://www.ebay.com/itm/Voltage-Reg...AAAOSwKWha~SzX
File Type: jpeg 8BCCA020-27ED-4E12-86E6-7EF6069DE732.jpeg (24.4 KB, 29 views)
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 07-08-2018, 09:26 AM   #2
sam_sam_sam
My Country: USA
Default ZD-915 Controller Desoldiering Gun to control heater element
I have tried this controller with the item above and it works but still need to control on and off the heating element
File Type: jpeg 8C21D602-5AD5-4427-899A-86B1719B7D92.jpeg (21.7 KB, 15 views)
Old 07-08-2018, 09:32 AM   #3
sam_sam_sam
My Country: USA
Default To control the heater element ON/OFF High Current 210A MOSFET Upgrade RAMPS
I have ordered some of these to try them out has anyone used this module before
3D Printer Heated Bed Power Module Board High Current 210A MOSFET Upgrade RAMPS
Here is the link to this module
https://www.ebay.com/itm/3D-Printer-...53.m2749.l2649
I do have a question
Do I put the print heat element controller first then the voltage regulator or do I put the voltage regulator then the heat element controller which way would be better and WHY
File Type: jpeg A12B7EF3-E961-4DED-84E7-47315DFF1411.jpeg (51.1 KB, 7 views)
Old 07-08-2018, 09:43 AM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Has anyone used this module before Voltage Regulator DC 4-40V To DC1.25-36V 8A 20
i think you forgot to say what your trying to do!
stj is offline   Reply With Quote
Old 07-08-2018, 09:52 AM   #5
sam_sam_sam
My Country: USA
I want to control the heater element to run off of a 20 volt battery power
I tried to use the controller board off of switching power supply minus the switching power supply portion of it
Well this would power the ZD-917 controller board ok but the it would not control the heater element the mosfet was turn on fully on and blew the mosfet and burn the heat element out
My guess is that some how the switching power supply was sending a signal to ZD-917 controller to control the mosfet
I thought about trying to hack the switching power supply module board again but I have no way to get another one easily
The reason I tried this was because I had one board that the board was having problems powering the Desoldiering gun
Old 07-08-2018, 09:54 AM   #6
stj
stj's Avatar
20v input,
what's the heater voltage & current?
Old 07-08-2018, 10:10 AM   #7
sam_sam_sam
My Country: USA
Quote:
Originally Posted by stj View Post
20v input,
Here is the test data that was done
The heater element with no controller 8 amps @ 12 volts
The switching power supply ( 30 volts @ 10 amps maximum ) that I was using the voltage would not get any higher than that but I can not leave it running like that very long because the heater element glow very bright and then burn out
One note the Desoldiering gun and the soldering iron have very smilier results the soldering iron heater element amperage is a little lower
Old 07-08-2018, 01:21 PM   #8
stj
stj's Avatar
ah, so your trying to run the desoldering unit off 20v dc?
Old 07-08-2018, 02:30 PM   #9
sam_sam_sam
My Country: USA
Yes that is the plan
I am not worried about the suction pump running on 20 it will just run faster and give more suction
The problem is the heater element
controlling it safely and the results be repeatable and be reliable as is when running of 120 volts ac
Why I am trying to build this setup is because there are times when I have to repair a soldering joints on a machine controller board
and if I had this battery operated setup where I could do this repair at the machine then I would not have to take the item completely apart to repair it
also most our machines do not have 110 volts easily available and not always an outlet near the machine
Here is a bigger reason I wanting to this is to see if it can be done and it works correctly
Here is cost that I encounter so far
ZD-917 Controller ( for one unit) $15.00 plus $5.00 for shipping
Voltage Regulator DC 4-40V $4.00 free shipping
3 D print bed heater element controller $7.00 free shipping
If I get this setup to work correctly
I will post on this forum
I will show photos of what the inside the unit looks like
How it was put together
What I had to do to make it work right
So all together its about $26.00 and two broken unit ( ZD-915 and a ZD-916 ) case and other parts from the broken units
This has been an ongoing project for a long time I have tried different ways of controlling the current of heater element and nothing has work correctly so far
I want the ZD-917 to control the temperature of the heater element so I can still see the set temperature of the Desoldiering Gun / soldering iron temperature and see the current temperature is at the same time
Old 07-08-2018, 07:40 PM   #10
stj
stj's Avatar
it should run at 20v,
i suspect the problem is the DC, most soldering stations use zero-crossing switching - dc has no 0 point so the switching will latch on or off.
Old 07-08-2018, 08:26 PM   #11
sam_sam_sam
My Country: USA
I figured it would have to be something like that
I posed the question earlier about which should go first the voltage regulator or the 3 D heater element controller or would it make a difference which one is first
Old 07-09-2018, 04:19 AM   #12
stj
stj's Avatar
just look at the circuits on the controller - look at how the triac is driven and look for any thing connected to ac other than a rectifier.
Old 07-10-2018, 04:04 PM   #13
sam_sam_sam
My Country: USA
UpDate
The 3 D printer heater element controller will power heater element with no problem
I have to change the resistor for the optic sensors because the turn on voltage is about 9 volts surface mount resistor value ( 103 )
I need the turn voltage need to be 3 volts
Old 07-10-2018, 11:03 PM   #14
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
So based on your measurement, the heater draw 8 A @12V, that means it has 1.5 Ohms (12V/8A) resistance, so when 30V is applied to the heater, it will draw 20A (30V/1.5 Ohms), so if your power supply can supply 30V then the power will be 600W! instead of 96W at 12V. No wonder it burns up, I am surprised the power supply did not go into shutdown.
__________________
budm is offline   Reply With Quote
Old 07-11-2018, 03:14 AM   #15
sam_sam_sam
My Country: USA
Quote:
This power supply regulate the current and voltage it is a bench switching power supply so if you try to pull to much current it lower the voltage
I have the voltage set at 20 volts
The voltage drops to 12 volts @ 8 amp
If the voltage is set for 12 volts
The voltage is about 10 volts @ 5.5 amps
Even with this setting the heater element will start glowing it just takes longer for this to happen
I probably going to set the Voltage (PWM ) Regulator to maximum of 5 amps ( which is recommended ) to 3D printer heater element controller and the ZD-917 controller keep heater element from glowing
One note the voltage regulator module has a maximum rating of 8 amps and it will not let you pull more than about 7 amps ( at least from the testing that I done with it so far)
Here is the data sheet for the buck regulator IC chip
http://www.xlsemi.com/datasheet/xl4016%20datasheet.pdf
One note there is a mistake on this data sheet for the output capacitor it says 1000uf @ 25 volts
It should say 1000uf @ 50 volts
Step-down power supply module DC4-40v to DC1.25-36v 8A 200w adjustable XL4016E1 DC-DC DC voltage regulator buck module
Buck chip: XL4016E1
Input voltage: DC4-40V
Output voltage: DC1.25-36V
Maximum power: 200W
Output current: max 8A (long operation, recommended 5A)
Conversion efficiency: 94%
This is the plan let’s see if I can get it to work that way
Old 07-11-2018, 03:48 AM   #16
stj
stj's Avatar
the heater element is 80w @ 24v
i hope your not powering the thermocouple instead!
Old 07-11-2018, 04:08 AM   #17
sam_sam_sam
My Country: USA
I can not seem to add very well
The total is really about $31.00
Old 07-11-2018, 04:12 AM   #18
sam_sam_sam
My Country: USA
I will check this just to make sure that this is not the case
When I have had the temperature sensor error on the screen before the heater element would glow very brightly and if you did not catch early enough it would burn out the heater element
Old 07-11-2018, 04:26 AM   #19
sam_sam_sam
My Country: USA
Yes the label says this
However the switching power supply voltage version output is 18 volts
On the transformer version the ac voltage is 20 volts
So what up with this
So is 80 watt for real or is this some what ( more or less ) than this
Old 07-11-2018, 04:39 AM   #20
sam_sam_sam
My Country: USA
Desoldiering gun
This is the setting for the voltage regulator module the voltage at the heater element is going to be different
So if I want to get the wattage to be 80 @ 20 volts then I need to set the maximum amperage to 4
Soldering iron
So if I want to get the wattage to be 60 @ 20 volts then I need to set maximum amperage to 3
At least that what I have come up with
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
