What do these capacitors do.. ?
    Hello
    Please can someone shed some light to what these 3 capacitors actually do.
    C5502, C5503 and C5504.
    I am waiting for new ones to be delivered plus the fuse.
    I am expecting the fuse to arrive first so would like to know if I can try the laptop after ive replaced the fuses without the capacitors.
    Or even does the laptop need these capacitors to work ?
    See attached
    Cheers
    Re: What do these capacitors do.. ?
    Filter caps.
    Are they tested bad or what?
      yes motherboard had a short to ground, apparently all three capacitors and fuse needed replacing, repairer couldn't return them as he lost them?? , I have ordered new.
      What would happen if I turn on without capacitors soldered onto board?
      Cheers
