Thank you in advance!!
Panasonic Toughbook CF-C2 please remove bios password!
Re: Panasonic Toughbook CF-C2 please remove bios password!
Originally posted by Andreasbest View PostI see the only change is 00000070 byte 0A changed from FF to 00 but didn't work either.
How is that possible?
Oh, well, that was a typo anyway.
I don't see a reason why this wouldn't work.
I have news.
With your (both) .bin i'm able to enter bios and change everything, except the supervisor password.
Seems like the password is stored to another location of bios too.Last edited by Andreasbest; 01-27-2021, 06:04 AM.
I have more news, my bios seems like it's modified to restore several settings when "load defaults" and also a Panasonic supervisor password that set as default.
Here is the link with info regarding bios ending with M like mine (M10) https://customrugged.com/m-bios-panasonic-toughbook/
So there is indeed a bios password elsewhere inside dump stored by Panasonic, probably in "default settings" section of bios.Last edited by Andreasbest; 01-27-2021, 06:32 AM.
Originally posted by Andreasbest View PostSearching with UEFItool meanwhileAttached Files
Thank you SMDFlea but i just bought a clean bios dump from a site, unfortunately none gives it for free.
Anyway, i managed to enter bios, supervisor passwords are clear and everything can be modified BUT
if i do "load defaults" the password returns and i must reflash the bios.
So these "defaults" are stored in bios chip itself OR somewhere else?
I suspect that this thread will become a guide for anyone that buys M bios Toughbooks.
Originally posted by Maxpower3 View Postyou tested "toughbook" or "panasonic" as the default password?
you can share us your file which works in mp
here is the file that worked too.
Please compare it to found out where is the supervisor password stored in my backup.
Although i have serious reasons to believe that is stored elsewhere than the bios chip since it's a M model like i said before.Last edited by Andreasbest; 01-27-2021, 09:20 AM.
Originally posted by SMDFlea View PostDid you try setting a new password rather than setting bios defaults. Theres another password for the Optional Kit Configuration: toughkit
With the bios i bought i can set a supervisor pw that works, unless i do "load defaults" then changes back to the unknown supervisor pw.
"toughkit" doesn't work either.
Panasonic did terrific job in this i have to admit.Last edited by Andreasbest; 01-27-2021, 09:46 AM.
Are you tring without the HDD attached. Post a picture of the pass screen.I doubt its stored in the EC ,what is the EC chip ?
Edit: did you remove the CMOS battery and clear it by shorting the battery pins for 20 seconds or so ?
.Last edited by SMDFlea; 01-27-2021, 10:28 AM.
Originally posted by SMDFlea View PostAre you tring without the HDD attached. Post a picture of the pass screen.I doubt its stored in the EC ,what is the EC chip ?
The screen is the usual Toughbook password screen.
Yes CMOS battery is detached from the beginning, no power on MB except the PSU when i plug it.
I also tried 20secs short circuit.
Well i'm almost convinced is stored into EC.
