How can I convert hp g62 discrete to uma
    motherboard part number : da0ax1mb6f0
    Re: How can I convert hp g62 discrete to uma
    The question is why would you do it? this does not make any sense to me.
      I do it for simple display problem repair, without Change chips.........@sopik78
      Do you understand this
        If you have simple problem, do it simple way. And it is definitely not to convert dis to uma on this board.
        Just get the schematic and compare the differencies between uma and dis version, it means to change a lot of parts and flash SPI to uma BIOS.
        Or get some uma board and match it with your dis.
        After this you choose other way for sure.
          ax1 is very difficult to convert, need to add and remove a lot of components.
            Not that difficult man, have converted atleast 5-6 such boards succesfully. It makes sense to convert from dis to uma as ati chip fails on this mobo.
            If you need i can post the knowhow to convert.
            No need to flash bios after conversion.
              can you please upload the tutorial for conversion please
                Here is the conversion details+Boardview(without which its very difficult to locate components
                Enjoy
                  thanks for sharing
                    If need arises, I can post my converted mb pic. You try it out first.
                      if it is ok can you post your converted mb please
                        Thank a Lot of all bad caps friends.......
                          Board viewer software for all Download and enjoy
                            thanks sir
                              Enjoy
                              thanks for sharing
                                thanks sir for sharing
                                  hi bro. is it working ?
                                    Yes, its working 100% provided you understand and do it right.
                                      Hi , very thanks bro.i will try.
                                        Hi, i have DAAX1JMB8C0 with the processor on board. Will it work? I tried except the seventh picture. But its not powers up.
                                        In 7th stage cant figure out the position of the capacitors.
                                        I have one difference in picture 2. I had 75 ohm resistors instead of 70 ohm in r497 , r498, r499
