Please I need bios for MSI GL62M 7REX (MS-16J91 ver1.0)
    Hello!
    The BIOS upgrade is wrong and the laptop won't boot.
    There is currently no bios backup file.
    If you have a laptop of the same model, please help with the bios file.
    Model: gl62m-7rex
    Motherboard: ms-16j91 (ver 1.0)
    please help me!
    Re: Please I need bios for MSI GL62M 7REX (MS-16J91 ver1.0)
    Post your original bios here.
    Become a Badcaps supporter
    Thanks to all supporters.
      There is no file backed up due to my mistake, and it is not possible to create a dump now. So I need the original bios dump.
        Today's your lucky day.
          hoaca388 thanks for the help.
          There was a problem with the bios chip, so I replaced it. I tried to rewrite the bios using CH341A, but it is not restored with the attached file. Did you dump it from the gl62m-7rex laptop?
          gl62m-7rex It seems that there must be a file dumped directly from the laptop for recovery.
          I may be wrong, someone please give me an idea
            That file is downloaded from the MSI homepage. Change "*.324" to "*.bin".
              transaction successful
                MSI GL62M 7REX no Post.
                Hello friend .
                I got this lap power on but no display ( internal and extaernal).
                All voltages are present , PLtrst too.
                I suspect bios if someone can help.
                Mine is : 16J93.3h1A , i try 16J93.324 with no result...try same too (16J93.3h1A) same issue...if someone can help more...thank you
                  Re: MSI GL62M 7REX no Post.
                  Originally posted by lapfix View Post
                  Hello friend .
                  try..
                    Originally posted by peste View Post
                    try..
                    thank you my friend but Same issue
                      maybe you have another problem ... have you changed the ram memory ??
                        Hello, does anyone with EC (ENE KB9028Q) file? the EC chip is burnt, I can't find any ec file.
                        thank you
                          thank you
                          cccccc
                            cccccc
                            THANK YOU!!
                            but unit powers on but no dispay.
                            i have replaced the KB9028Q chip and write the ec provided.
                            model: gl62m-7rd
                            board model: ms-16j91 ver 1
                            question:?
                            is it true that i should put empty SiO chip and the bios chip will write the SiO automatically?
                            thanks for the input
                              edit: i found the ec on their website.
                              thanks.
                              it works now
                                MS-16J91 ver1.0 ec bios?
