Dell Latitude E5540 power On than Off after 5 seconds.
    Hello my friend.
    Dell Latitude E5540 LA-A101P power On than Off after 5 seconds.
    At first i find a burned Capacitor PC437 ,after desoldered try to power on , laptop is on , fan spinning , 0.440 amp taken ; 5 seconds and he is
    Off.
    With diode mode try to find any short at all coils , but all is OK.
    In this 5 seconds try to take the voltages :
    Pl 400 = 19V
    PL 401 = 13.65v
    Pl 52 = 3.3v
    PL 53 = 5.21v
    PL 51 =13.65v
    PL 100 = +1.35V_MEN_P
    PL 150 = +1.05V_MP
    PL 300 =+VCC_CORE = 1.7V
    PL 200 = +1.5V_RUNP
    Bios PIN 8 = 3.33v
    PQ 400 = D=19v...G=0v !...S= 19v
    The gate here must be Low !
    U46 = +3.3V_RUN/+5V_RUN present
    U43 = +3.3V_ALW_PCH/+1.05V_RUN present
    U45 = +3.3V_SUS/+3.3V_M present
    UC3 = PCH_PLTRST#_EC = 3.3vTry to flash bios (3 chip ) same issue too !
    What would i check too !!
    Re: Dell Latitude E5540 power On than Off after 5 seconds.
    Most likely PU701 is damaged. PQ400 pin4 is not connected to the charging IC here. Its Controlled by PU701. So probe PU701 voltages. This is dell latitude baby!!!
      Thank you my friend.
      Yes this is latitude hhhh
      Ok , so if i m understand you , PQ400 Gate must be more than 0V !
      PU 700 :
      Pin 1 = DC_IN = 19V
      Pin 7 = DC_BLK_GC = 0V
      Pin 9 = P33ALW2 = 3.21v
      Pin 15 = PWR_SRC =19v
      Pin 18 = P33ALW = 3.3v
      Pin 22 = DK_AC_OFF_EN = 3.3v
      Pin 24 = ACAV_IN_NB =3.01v
      Pin 27 = P50ALW = 5V
      Pin 33 = DC_IN_SS = 19v
        PU 700 :
        Pin 1 = DC_IN = 19V
        Hi, there.
        I've got exactly the same problem with Dell Latitude E5540. All measurements are spot on. Have you found a solution.
          Hi, i have a similar problem with a Dell Latitude E5570, The 19.5V power rail is dropping to 13.65V not far after the input and that is being maintained around the board, but i am also getting the 5V and 3.3V.
          I dont think the 13.65V is correct, I will be getting the schematic soon so will have further info, and would like any feedback if possible.
            A simple thing like cleaning dried cooling paste and applying a new one can solve this kind of issues on dell.
            I notice dell is a very sensitive laptop, I've solve a lot of cases like this by just applying thermal paste and sometimes reprogram the BIOS.
              Hi, did you find out the problem? Same here, 13v on the main power rail but all other voltages are fine. Thanks.
                https://www.badcaps.net/forum/showthread.php?t=90356
                  13V on main rail is absolutely fine here.Your problem may be elsewhere. read the thread linked by @piernov to know what is narrow voltage charging technology.
