Dan97rmb6d0 rev d bios
    Re: Dan97rmb6d0 rev d
    Originally posted by zaraki7777 View Post
    this one
    thank you work 100 percent
      If the power light blinks 7 times and does not work, connect the led cable from the LCD panel to the motherboard, this is not a malfunction.
        Where is BIOS chip located on this board or what chip IC named please?
          Hello, I have the same issue motherboard DAN97RMB6D0 REV D
          I would really appreciate it if you can send me the relevant BIOS File
          The serial number is 8CC9252L86
          Model Name: 24-f0008nv
          Product ID: 4HC11EA#AB7
            Post your backup
              unfortunately I downloaded one of the bin files that you posted on thread and wrote on the BIOS without taking a backup!
                try this...
                  Thank you. still same issue, 7 white blinks right after plugging in the power supply.
                  Any idea?
                    Any idea?
                    did you measure voltages ?? what error code are 7 white lights ??
                      i need bios DAN97AMB6D0 REV N97A
                        HELP!!! Where is BIOS chip located on this board or what chip IC named please?
                          work sir thank you
                            Usually it is located near the CMOS battery.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              This helped me out alot. Thank you
                                Re: Dan97rmb6d0 rev d bios
                                Hello everybody
                                I have an HP 24-f0005nl which when turned on makes 3 long beeps and 4 short beeps and reading a bit on the web there could be several causes including BIOS corruption. I tried to replace BIOS RAM and battery but nothing to do, I would only have to try with the BIOS. Having no backup of anything and not booting the PC to video at all, is it possible to flash the BIOS in some way?? If so where could I find the BIOS?? Thank you all in advance and sorry for my bad English.
                                Serial Number: 8CC8230JZ3
                                Model: 24-f0005nl
                                Product ID: 4MZ14EA#ABZ
                                Mainboard: DAN97RMB6D0 REV D
                                  Originally posted by William990 View Post
                                  Hello everybody
                                  Model: 24-f0005nl
                                  HP All-in-One 24-f0005nl
                                    DAN97AMB6D0 REV bios
                                    hi. I need DAN97AMB6D0 REV : D bios .
                                    model :n97a
                                    my bios backup...
                                      Re: DAN97AMB6D0 REV bios
                                      model :n97a
                                      my bios backup...
                                      HP All-in-One 24-f0048nt
                                        hello guy ..help me please bios aio dan97amb6d0 rev : d
                                          Upload your Original Backup and write your device Serial Number.
                                          all donations are welcome,
