Caps needed
    Caps needed
    Hi everyone, can someone suggest to the admin to make a thread about what brand, type, value, and size that should be available for sale by BadCaps?
    I personally need a 10V 470uF 6.3mm Diameter cap but there's no such cap available here. The only site i know that has this type of cap is DigiKey, but the problem is the shipping cost is too expensive. The lowest shipping cost to my country is $32 I could use that to buy 20+ poly caps.
    Or does anyone know where to buy good caps with complete brand, type, value and size that also ship worldwide and has a reasonable shipping price?
    Re: Caps needed
    http://cgi.ebay.ca/10-NCC-KY-Series-...item43a84bf382
    He has a good reputation, I have bought from him before. His caps are not fakes!
      Re: Caps needed
      Thanks bigbeark, but they don't have 10V 470uF 6.3mm Diameter cap too.
        Re: Caps needed
        If this is for a motherboard then a 6.3v cap can be used [as long as ESR is as low as old cap].
        Mobos only have 12v, 5v, and 3.3v.
        You know a 10v cap is not on +12v power.
        That means it's on 5v or less,, so a 6.3v cap will work fine.
        That trick does not work if it is not a motherboard.
        If it's not a motherboard you would have to measure the actual voltage to know if a lower volt cap would be okay.
        Mann-Made Global Warming.
        - Dr Seuss
          Re: Caps needed
          What is this 470uF cap's Ripple and ESR?
          - Dr Seuss
            Re: Caps needed
            Wow man, you're a tool!
            Either of these will work:
            https://www.badcaps.net/store/produc...roducts_id=119
            or
            https://www.badcaps.net/store/produc...roducts_id=148
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
              Re: Caps needed
              Great info PCBONEZ, thanks. But what about the uF should i use the same or is it better to have a higher uF? The only 6.3mm diameter 10V cap i found available has only 330uF capitance, is it ok to use that? I also found this 6.3V cap, which one should i buy?
              As i mention in my thread it's for Intel mainboard it has alot 10V 470uF 6.3mm Diameter scattered all over the board.
              It's Nichicon VR 10V 470uF 6.3mm Diameter. I don't know the spec BONEZ .
              I'm sorry Topcat, but the diameter doesn't fit in, i need a 6.3mm
              This is frustrating.....
                Re: Caps needed
                Ahh, my apologies, I just looked at the value and voltage, diameter got by me.... Good luck on your search. Digikey will have something compatible I'm sure, or maybe mouser.
                Team : 49813
                Join in!!
                Team Stats
                  Re: Caps needed
                  Nichicon VR 10v 470uF is a size 6.3x11 GP with rated ripple 350.
                  NCC KZH 6.3v 470uF is a size 6.3x11 Low Impedance/Long Life with rated ripple 500.
                  So, the KZHs you found, should work fine.
                  Be a mensch
                    Re: Caps needed
                    I agree, those KZH look like the way to go.
                    470uF in 6.3mm is a bit hard to find. Most are 8mm.
                    - Dr Seuss
                      Re: Caps needed
                      Did find two others if you want to check availability:
                      Chemicon LXZ, 6.3v, 470uF, 6.3x15mm, 400 mA
                      Nichicon HV, 6.3v, 470uF, 6.3x11mm, 550 mA
                      - Dr Seuss
                        Re: Caps needed
                        I think I've seen a few models of boards with them in all these years....The most common ones were ECS P3 boards with these in g-luxon, that were in some kind of arcade games that a client sent me many dozens of for repair. Of course they were all toast. A 470@10 ZL 8mm worked fine. They were spaced out well, so fitment was not a problem. If they were crammed like the OP says, no, an 8mm would not be a good choice. Looks like I may need to look into having a small stash of these.
                        Team : 49813
                        Join in!!
                        Team Stats
                          Re: Caps needed
                          I ran across them in an Akai LCD TV. - I used LXZ. Bought extra.
                          I didn't even remember that until after I posted and checked my stock to see if I needed to get some.
                          - Dr Seuss
                            Re: Caps needed
                            Thanks alot sofTest
                            Yup, i've ordered it . You are very helpful PCBONEZ, you
                            Yup, i would stock them too. Next time i'll try to get a board with only 10mm and 8mm caps onboard
