Asus N71VN burned Power Connector
    Re: Asus N71VN burned Power Connector
    nice vid, makes me wonder where the hell it's getting the + from!
    maybe peeling that top track away would stop it.
      LOL, after the dremel it worked on first attempt !
      I don't have anymore the short between + and -, it's better if i resolder backe the inductors and capacitor ?
      Crazy, you really need to remove all the charcoal, otherwhise short will remail !
      Thank you all of you buddys
      PS: Now need to run final tests
        that's a big hole!
          Originally posted by stj View Post
          that's a big hole!
          Yeah, now it's just a big hole, not a Black one
          Just finish solder back the 4 removed smd's, now will rest before i atempt to put back the connector
            Ok, pc is 100% Working, battery is charging !
            The + Pin of the power connector is not touching the mobo, i used a wire to connect on the other side.
