Need Bios hp 14-dq DA0PADMB8 rev :F
    I need bios laptop fo hp 14-dq1037wm
    MB NO IS DA0PADMB8 rev :F
    Re: Need Bios hp 14-dq1037wm
    posts the original laptop bios
      model:opad
      DA0PADMB8f0 rev: f
        model:opad
        DA0PADMB8f0 rev: f
        Can you dump original bios ? If not ,you must flash all this bin files , one by one.
        Become a Badcaps supporter
        Thanks to all supporters.
          What is about ec bios?
          Is it5570e programmable
            I've never tried EC programming, it looks like it's in the I/O. EC files can be retrieved from the bios.
              Thank you my friend.
              It is work
                Same computer here (HP 14-dq1038wm, motherboard DA0PADMB8F0 REV:F).
                I've tried all of this four bin files with no success.
                Do I have to program all of them, one after another ? Or program each bin and check if computer turns on ?
                The chip is Gigadevices 25b127dsig. It may be faulty. Do you think I can replace it with Winbond 25q128fvsg ? I've checked datasheets and they look very similar.
                  Yes, you can change them.
                    Thank you for replying.
                    When you say "one by one" do you mean to flash each bin until I find the correct one ? Or do I need to flash all of them before turning on the computer ?
                      That is, flash each one, turn on the device to test, if it doesn't work, flash the other one.
                        I have tried flashing each one. No success.
                        I replaced the original chip with the 25q128fvsg.
                        Flashed each bin and tested again. No success.
                        The computer power led turns on for a couple of seconds then it turns off, in a loop. No fan, no backlight.
                          Your case just try 16MB bios files, maybe your motherboard still has other hardware errors.
                            Could be.
                            But before flashing it the computer turned on and showed a message like "Bios corruption detected". I tried to update bios using a usb drive but it could not finish, always an error was found when verifying the written data.
                            I decided to try flashing the chip with a programmer but got the same errors when verifying. I got a different chip, a winbond. It reads and writes ok, also verifies the written data but the computer does not turn on. Only the power light turns on and off in a loop.
                            Maybe the ics are not compatible ? I cannot find a replacement for the original ic here.
