Battery resistance measurement with cap ESR meter
    Hello, I have ESR70 and this schematic was sent to me.
    1.Can I use some non electrolytic cap so connection polarity does not matter?
    2.What cap would be best? super low ESR and small size would fit in standart RCA JACK?
    https://canada.newark.com/lumberg/15...mm/dp/05AC9675
    3.Is resistor needed, why?
    4.Anyone compared such measurements with proper meter for battery internal resistance?
    Re: Battery resistance measurement with cap ESR meter
    Where did you find this information from can you please post the website link to this information request
    thanks
    Because I tried to search for this information but could not find anything
    If you could provide me with this information I might be able to answer your question
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      You should use a cap as small as possible that has a very low ESR, ideally much lower than of the battery. A plastic capacitor will work if you can find one that has low ESR at the frequency your meter tests at.
      The resistor is to equalize the jig to prevent the meter from damage or deal with dc offset.
        I have heard about this way of testing ESR of batteries before but I have never seen anything about how to do this and how to interpret the results
        Do you by any chance know about how this is done and how you interpret the results
        If so could you please explain how this is done thanks
        9 PC LCD Monitor
        1 Dell Mother Board
