I have a Dell gx280 and My mobo is fried all 9 of the caps between the cpu and the printer port are either leaking a yellowish powder or look like a frozen beer can. There are nichicon 1800uf 6.3v 8mm X 20mm 105 degrees and i have looked on digikey and I could not find anything near that diameter. So I found some on ebay and to no avail they are 13mm and will not fit without overcrouding each other. I guess I could rig them in there but i want to do this the correct way. So I have looked some more to no avail but a local electonis store has some 2200uf 6.3v 10mm X 20mm but are 85 degrees. Will these work or should I keep searching? the closest digikey had was a panasonic that was a 1800uf @ 6.3v but was 12mm this will not work. too big. what to do next???
Can I replace a 1800uf with a 2200uf 6.3v?
Re: Can I replace a 1800uf with a 2200uf 6.3v?
So I have looked some more to no avail but a local electonis store has some 2200uf 6.3v 10mm X 20mm but are 85 degrees. Will these work or should I keep searching?PeteS in CA
It is safe to sub 2200uF 16v caps in place of those 1800uF caps, I do it all the time with the ones behind the heatsink. They must be low ESR, and 16v though. There's 12v on their positions, so it wouldn't be wise to decrease the voltage... lol The 8mm 1800uF 6.3 volters, I'd sub those with 1500uF caps, as those are easy to obtain in 8mm cans. Stuffing 10mm cans in those spots would be nearly impossible.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
If the originals are 6.3 volt then yes you can use 10v or 16v, but they will have larger dimensions and there is really not much meaning with it
But on the other hand it does not do anything bad to go up in voltage... Never go down in voltage though..."The one who says it cannot be done should never interrupt the one who is doing it."
