Query on 24V supply
    Query on 24V supply
    Hi Folks
    have a basic question on Fundamentals. I have a Power supply that has the following terminals +12V, 0V and -12V. Now normally i can get 12V by connecting between 0 and 12 and -12V by connecting load between 0 and -12V. I can also get 24V by connecting load between -12V and +12V.
    Now my queries
    1. Is the 24V i get by connecting load between -12V and +12V same as connecting the load between a 0V and 24V power supply. Is there anything to take care of when using one source against the other ?
    2. Now assuming there are 5A fuses between 0V and -12V and also between 0 and 12V. Now when i connect the load between -12V and 12V, would these fuses come into play?
    Re: Query on 24V supply
    is the + and - rated for the same current?
      Yes they are rated for the same current 5A
        then you can get 24v, but you cant connect the psu to anything earthed
          can i use this voltage/source on components that have specified range of 0-24V. For eg: if i am using an IC whose VCC pin range is 0-30V can i use this power source ?
            yes, but as i said - no part of your circuit can connect the 0v(GND) rail to mains ground.
            not unless you modify the psu first.
