what are these black things to the right of the ic chip . ? both test as shorted .
John Deere AM137667 components identification .
Re: components identification .
The one on the left could be an ON semi 1SMB26AT3 ,marking ME https://cdn.badcaps-static.com/pdfs/...70e6d21d8e.pdf
Originally posted by SMDFlea View PostThe one on the left could be an ON semi 1SMB26AT3 ,marking ME https://cdn.badcaps-static.com/pdfs/...70e6d21d8e.pdf
ok i only just thought to look on the board for same marked components and found the same S2g one and it measures as a diode on the board . i need to remove it to know for sure .
that leaves the other one marked ME . it doesn't measure any inductance so this might well be a shorted tvs diode as suspected .
will see what pins it connects to on the ic chip if any .
Originally posted by petehall347 View Postok i only just thought to look on the board for same marked components and found the same S2g one and it measures as a diode on the board . i need to remove it to know for sure .
3.2 Load dump protection
D ld is necessary (Voltage Transient Suppressor) if the load dump peak voltage exceeds the
V CC max DC rating. The same applies if the device is subject to transients on the V CC line
that are greater than the ones shown in the ISO 7637-2: 2004(E) table.
To me this board looks like shit with all of what looks like flux
What is the description of the device9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Originally posted by sam_sam_sam View PostTo me this board looks like shit with all of what looks like flux
Originally posted by stj View Postwhat does it actually do?
these particular boxes seem to have a large fail rate and it would be good to find and fix whatever the weak spots are .
Why not do away with the this controller board and do like older version does it sense it only controller the PTO and ground the ignition coils when ignition is off make it simple to use and operateLast edited by sam_sam_sam; 03-05-2022, 05:45 PM.9 PC LCD Monitor
1 Dell Mother Board
Originally posted by sam_sam_sam View PostWhy not do away with the this controller board and do like older version does it sense it only controller the PTO and ground the ignition coils when ignition is off make it simple to use and operate
now i have a problem finding the parts . RS dont appear to have them and none on ebay in this country . . are there any suitable subs ? https://uk.rs-online.com/web/zr/?sea...d%22%3Atrue%7D
does this look right one for 1SMB26AT3 ? https://uk.rs-online.com/web/p/tvs-diodes/8062019
does this look right for the other one ? https://uk.rs-online.com/web/p/schot...fiers/6291426/
are these the correct ones .
1SMB26AT3,,,
S2g-13-f...
i do have a thread running but not getting replies . i could do with getting these ordered .
