Need for testing short something draw 5,10 or 15 amp
    Re: Need for testing short something draw 5,10 or 15 amp
    Halogen or regular lamp still have to deal with Hot and Cold resistance, a positive temperature coefficient of resistance. which can be more than 10 times.
      Get a car headlamp bulb, should be good. It draws about 4-5 amps.
      If you get halogen capsules, make sure you encapsulate it in something for safety in case it ever explodes.
        Originally posted by macattack600 View Post
        What size type you recommend.
        I think you should get several, 5w, 10w, 20w or so. Start with the lowest and work your way up to prevent board damage.
        Of course, if the filament's cold resistance is too low, you may get the same problems as without it. I am not sure what the cold resistance of those bulbs is.
        -David VanHorn
          Cold:Hot resistance can easily be more than 10 times.
          Learn more here on what to watch out for when using switching device with the lamps.
          I.E.
          2 Lamp Switching
          Before an incandescent or halogen lamp is turned on, the filament temperature and resistance are initially very low.
          At turn-on, the temperature of the filament starts rising from the ambient temperature.
          The low initial resistance causes large inrush current into a lamp, which can be more than 10 times the nominal
          current. The solid-state switch should allow this inrush current to flow in the wiring harness, but only for a specified
          time (<100 msec). Once the lamp is fully on, its steady-state current depends on the supplied voltage.
            I'm thinking the car headlight is a bad idea. If I got the math right:
            A car headlight that takes 5A will be 60 watts.
            This means hot resistance will be 2.4 Ohms. That is OK if you want to draw that much current..
            But as budm says, divide that by 10 to get the cold resistance, and the cold resistance is going to be something like 0.24 Ohms.
            This means that when you first apply power, the filament is cold and the resistance is only 0.24 Ohms, we get around 50A of inrush current, this may blow the board and\or shutdown the PSU, and we're back to the same problem we had with no current limiting.
            -David VanHorn
              Thanks, AGENT. see the PDF in my post #24.
                So your saying is use a resistor in combination with the led rope light?
                  That would work but would be complicating things, one or the other would work by themselves.
                  Unless you are thinking of getting an LED strip that has no inbuilt current limiting, in which case a resistor or such would be needed to stop the LEDs from burning themselves up (bare LEDs need current limiting too!)
                  -David VanHorn
                    This is what a benchtop variable power supply is for ? In testing like I'm trying
                      Also what about using a 12v that does'nt shut off
                      Yes, a benchtop\lab power supply with an inbuilt current limiting feature can be used. This is a very good solution, in fact, because you can control exactly how much current you supply and you have no issue with it shutting down.
                      Word of warning: Do NOT use something like a car battery which not only has no current limiting, also has no short-circuit shutoff either. A car battery can and will supply 120A easily, and your board may very well turn to charcoal.
                      -David VanHorn
                        This is interesting.
                          There are so many ways:
                          https://www.badcaps.net/forum/showthread.php?t=31683
                          http://www.linear.com/solutions/5297
                          http://electronics.stackexchange.com...h-power-supply
                          http://www.tonystrains.com/tonystips/2011/021011.htm
                            Do you think the led light rope need to have a ground wire I believe it's only hot wire and negative on them. Or would I just be running the negative end to the ground of PSU? I do plan on trying this on boards not have much use for first.
                              So is there a way to make variable current device for the psu's 12v rail? The Psu I have says 9.2amp for the 12v.
                                You can probably use a circuit like this: http://www.eeweb.com/blog/extreme_ci...e-power-supply
                                Not sure if it will output a full 12v though, you might get only 10v, but that should be enough.
                                -David VanHorn
                                  I've learned alot today you've been awesome help but I think I can't take it anymore I'm going to buy led strip tape I've read 6ft takes 1 amp.
                                    If you want to be sure on the details, post a link to the one you are thinking of buying and we can see if there's any info to be found about it.
                                    -David VanHorn
                                      what exactly are you doing again?
                                      i originally thought you were trying to find a short?
                                      now it looks like your trying to load a psu down.
                                        I believe he wants to try 'smoke out a short' with an ATX PSU, obviously this will trip the SCP or roast the board.
                                        He wants a suitable load in series with the board to limit current and avoid those two things.
                                        -David VanHorn
                                          so a milliohms meter is too obvious then?
