Re: Ripple Current ?
Hi Joe
Its not rocket science mate...sure you can get very technical
but its just mostly understanding Ohms Law
what Voltage is, what Current and what Resistance is
some understanding on what DC is AC and frequency and a some magnetics
Then a little understanding on some components and you have pretty much got the basics..well enough to do what you want to do.
look of the links posted thought out this thread and you will find other stuff too.
just remember 3 things about voltage and current resistance
voltage exist across (or between 2 points)
current flows through (from one point to the other)
resistance is opposition to current flow
but it has an inverse property of allowing flow of current too (conductance)
(so you have to takes with it, how well it blocks or how well it allows current to flow.... depends on which side of the fence you want to look at it from )
I know the above seems way way simple
but if you can grasp it and apply it to what you read on the net it will dawn on you whats happening.
you got any questions post away
just remember with electrolytic caps, don't ever exceed the voltage marked on them (or stickem in back to front)
Thats quite a clever use for the cap thought, using it as a spare short term supply when a contact goes open circuit...makes perfect sense of your term flywheel too
Hope it helps
Cheers Joe
Hi Joe
Hope it helps
Cheers Joe
