Need help identifying smd
    Re: Need help identifying smd
    So the processor is the problem. Can't be corrected without replacing the processor?
      Or the processor detects fault or what ever the exact problem is so it shutdown that control line, I do not the details of how this unit is designed to function, that is why you did see the Voltage on the Collector of Q12 did the toggle LOW and HIGH due to activity of the processor output that feeds Q33 Base.
        Code:
                VCC   5V = power on
                +  0.22V = standby
          display |   |
            o----+ Q12 |
          5V = OFF \|  |
          0V = ON  |----+
               <|  |      hi = OFF
              |    \|  ___  lo = ON
              |  Q33 |--|___|---o
              |    <|     from micro
                GND
        KTC3875-GR / BR3DG3875M, KEC / Blue Rocket Electronics, NPN transistor, 60V 150mA, hfe = 200-400, marking HALG or ALG:
        https://cdn.badcaps-static.com/pdfs/...ef4b37225e.pdf
        https://cdn.badcaps-static.com/pdfs/...2ec8d6d3bf.pdf
          So just for reference, how does a processor turn an LCD display on?
          Does it first send backlights signal then once that's on it turns LCD display on?
          Doesn't make sense why if it's on it stays on but soon as it's turned off it won't come back on unless you keep trying
            Can you give us the part numbers of the major ICs and the model number of the device?
              I'll provide part numbers of major ICs when I'm home but it's an Absolute DD-3000ABT
                Is there a PDF manual for this thing?
                  I don't know I couldn't find one
                    What about an FCC ID? Sometimes there are useful documents in the FCC database.
                      Don't see an FCC ID unfortunately
                        Where would the main processor most likely be located, the circuit board with DVD drive/psu or circuit behind the LCD assembly?
                          Ok here's the area where Q12, Q33 are. There's another transistor Q60 that feeds 1.5v to base of Q33 through R193. It's base isn't connected to anything though, how does that work?
                          It's emitter connects to R154 which goes out to a pin that I traced to a chip right under the DVD drive. I'll post a pic of that next as my phone only allows one pic per post. I'm not sure if this is power for the DVD drive or linked to power on for the LCD?
                            R154 connects to pin where I marked with a red line. There's no trace going to it on the board though?
                              The Base of Q60 is connected to R324, another end of R324 goes to the VIA to connect to what ever, the board may be more than 2-layer board.
                                The end of R324 that connects to base of Q60 has 1.95v when the display doesn't turn on. The other end of R324 has 5v
                                When the display come on, base of Q60 drops to .70v 5v stays same on other end of R324. Is it normal to have that big a voltage drop across a resistor?
                                I wish I could figure out what's not switching every single time.
                                  You can esily find out if the Transistor are switching as it should or not by check the DCV between E and B, and E and C.
                                  if E and B changes state then E and C will also change state.
                                  You should look up on how Transistor operate.
                                    Ok I have a question. When the display doesn't come up on Q60 there's 1.92v on the base and 1.25v on emitter and collector. When display comes on there's a difference of those voltages on the collector at .67v
                                    Does this show something wrong with that transistor or something else?
                                      'Q60 there's 1.92v on the base and 1.25v on emitter and collector'
                                      You need to check the Voltage between the E pin and B pin, and between E and C pin. What are they?
                                        B and E .65v
                                        C and E 0v
                                          Originally posted by caphair View Post
                                          B and E .65v
                                          C and E 0v
                                          As I explained before, as you can see, the E-B junction of the transistor is bias ON, so the Voltage between E and C will be close to 0V (Transistor is turned ON , saturated condition).
                                          https://learn.sparkfun.com/tutorials/transistors
                                          https://en.wikipedia.org/wiki/Bipola...sistor_biasing
                                          http://www.electronics-tutorials.ws/...r-biasing.html
