Can anyone help me identify this transformer?
    Re: Can anyone help me identify this transformer?
    I can see the pictures in post #1, #5.
      different browser settings.
      hardly the point - the foto's wont last long at that url - i learned that the hard way & stopped using these "cloud" bastards.
        I know I know, photobucket is garbage........
        I feel like I should be checking both the big cap and the diodes for leakage, I read something like if they're faulty a large ripple current will be sent through the cap causing overheating, any truth to this?
        "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
        -retiredcaps
          Upon further inspection it seems that there are a few more suspicious caps I didn't see, could one of these be the culprit?
          -retiredcaps
            Interesting development.........
            I was able to power up the panel with the case off, turns out it's not the transformer that's overheating but rather the cap circled in this picture, which is on a separate board. The cap was cracked open and burnt so I replaced it but the new one is getting just as hot, and it happens much quicker than I previously thought.
            Between this thread and my other one with the displays for this panel, this project is quickly turning into a trail of fail
            -retiredcaps
              More shots of the board...
              This picture is of a donor board, the cap shown is the one that's overheating on the actual board
              -retiredcaps
                Do you have any ideas why the cap is over heating
                9 PC LCD Monitor
                6 LCD Flat Screen TV
                1 Dell Mother Board
                15 Computer Power Supply
                All of these had CAPs POOF
                  I'm hoping the experts will chime in and have an idea of what's going on.
                  When I test all those caps on a good board in circuit(not a reliable test) they behave normally(I get a reading then it jumps to OL or just says OL.)
                  On this board, all of the ceramic disc caps give me a steady reading of ~.500
                  Something's definitely not right.......
                  -retiredcaps
                    do you have a scope and/or a frequency counter?
                      I don't unfortunately, it's the last tool I need, the more I work on electronics the more I realize how priceless it is.
                      -retiredcaps
                        Are you sure thats a cap. and not a ntc thermistor or maybe a MOV is it marked RV? next to the removed RV2 If its a thermistor it will get warm, if its a mov it is most likley bad
                          It is marked RV1 on the board, here's the specs: http://www.alliedelec.com/m/d/2f6776...201ab01eb3.pdf
                          I'd understand it getting warm but it's getting burning hot within seconds while the one right next to it is completely cool
                          -retiredcaps
                            Which value/part number did you install
                              EZRV20D241 - V20241U
                              It was an exact replacement from another board
                              -retiredcaps
                                Its a Transient/Surge Absorber, If its getting hot its getting more than 150v a/c or more than 200v dc according to the specs, It is across the 120v a/c line?
                                  Do you have the wiring diagram to find out what kind of Voltage is supposed to be applied to those two terminals?
                                    If you're looking at the picture, the terminal farthest to the right is ground and the other one is 120VAC
                                    -retiredcaps
                                      So that MOV is across the LINE which how it is used, in normal condition it should not be conducting any current at all. It is for protection, not for the operation of the circuit.
                                      So for it to get really hot like that, I would remove it and see what kind of resistance you are getting.
                                        Panasonic ERZ-V20D241
                                        http://www.mouser.com/ProductDetail/...jQGa7MJQ%3D%3D
                                          Thanks bud, it's interesting because once I changed it out the same thing happened, you want me to measure the resistance of the MOV? Surely I didn't replace the bad one with another bad one........that current must be coming from somewhere it shouldn't be, maybe I'll test that with a working panel.....
                                          -retiredcaps
