Help Identify Capacitor
    Re: Help Identify Capacitor
    No i didn't have the main board connected. Figured if the fuse held longer than a split second I could power off then connect the main board. But the fuse just blew too fast.
    at + & - of bridge i get.4 ohm
      Also since it blew so fast there was no 13V
        .4 Ω is basically a short so something is sorted after the bridge
        Check diodes dp802,dp803,dp808c, fets, QP801CS, QP811CS, QM801CS,QM802CS
        You can check the resistance across CP811s/812s, If it checks shorted, Unsolder the 2 jumper wires J829 & J830, then check the resistance across cp811s and then across CP812s, this will isolate where the short is.
          dp802 - .552V and OL the other way
          dp803 - .555V and OL the other way
          QP801CS - between source and drain it beeps; between gate and source 324 ohms
          QP811CS - between source and drain it beeps; between gate and source 133 ohms
          QM801CS - neg lead on D & + lead on S = 494 ohms; + lead on D & pos lead on S = OL
          QM802CS - neg lead on D & + lead on S = 493 ohms; + lead on D & pos lead on S = OL
          CP811 - in circuit shows 128 mico farad that's with my meter set to read capacitance
          With meter in resistance mode it starts at 143k ohms and then rises up
          CP812 - in circuit shows 128 mico farad that's with my meter set to read capacitance
          With meter in resistance mode it starts at 143k ohms and then rises up same as CP811
            well if those are the readings, then it must be the bridge rectifier that is shorted
              Removed the Bridge rectified off the board, tested good
                Then where are you getting the .4 ohm reading when checking across + & - ? If you are reading .4 ohms across + & - of the bridge, remove CP801S & CP802S If they are ok, and the short is still across +&-, check CP811, (another small blue cap)
                Or DP808c (you did not report resistance) or the capacitor you installed is shorted??
                  Have you checked the two items that are near “J828” that are on a heat sink what are they part number
                  9 PC LCD Monitor
                  6 LCD Flat Screen TV
                  1 Dell Mother Board
                  15 Computer Power Supply
                  All of these had CAPs POOF
                    So what are the resistance between Source and Drain for those two PFC MOSFET's? It sounds like the PFC MOSFET's are shorted out or the snubber caps for them are shorted out since they are connected in pareallel.
                      this is the problem when people say the meter beeps and not give an actual resistance reading. could be shorted fets.
                        +10, I do not know why people use beep mode to look for shorted device/circuit, most meter will beep with resistance as high as 50 Ohms.
                          I just checked one of my meters on a 120Ω resistor and it beeps.
                            R_J - Yes resistance on rectifier was in circuit and between + & - is was .4
                            CP801S with meter is resistance mode - i get 3 ohms
                            CP802S with meter is resistance mode - i get 3 ohms
                            CP801S with meter is capacitor mode - I get a split sec 0 micro farads then OL
                            CP802S with meter is capacitor mode - I get a split sec 0 micro farads then OL
                            DP808C - starts at 72k ohms and just climbs kept climbing past 100K ohms if I read it again it starts at say 140K & just climbs
                            CP813 (the one that was blown and I replaced - in capacitor mode in one direction +/- meter leads I get 426 micro farads, in the other direction +/- meter leads I get 128 micro farads
                            CP813 with meter in ohms - starts at 72k ohms and just climbs kept climbing past 100K ohms if I read it again it starts at say 140K & just climbs
                            sam_sam_sam - the components are QM801cs they say they are 1E03AU FDPF 8N50NZ on the board the seemed to test ok
                            BUDM - QP801CS & QP811CS maybe I tested these wrong the first time. But here is what I got this time with meter in resistance mode I left the bridge rectifier off the board
                            QP801CS - between S & D diode mode = beep; between G & S 334 ohms
                            QP801CS - between S & D resistance = .1 ohms; between G & S still 334 ohms
                            QP811CS - between S & D = diode mode = beep; between G & S 144 ohms
                            QP811CS - between S & D resistance = .1 ohms; between G & S still 144 ohms
                              If this is the results you got then you have a problem with this device between the S & D looks it is shorted ( does it matter which way you have the test leads in diode test mode do get the same results )
                              Take them out of your board and see if you still read the short that was on the bridge rectifier + and - if still does then still have more work to do to find what else is still shorted
                              This is the part number 8N50NZ
                              9 PC LCD Monitor
                              1 Dell Mother Board
                                QP801CS & QP811CS are both part no. 13NM60N
                                QM801cs which seemed to test fine in circuit is part no. 8N50NZ
                                Also, what's that white stuff on the ternimals? Feels like white silicone, can do I have to replace that after?
                                  At this point, the Gate Drive output of the PFC IC may be damaged when the MOSFET's shorted out so when you put in new MOSFET's they may get damaged, I would suggest to replace IC at the same time or take the chance of blowing up new MOSFET's.
                                    bubm - can you tell me the number on the board of that IC so i can locate it
                                    The IC i read is ICP801 and it says S3051 but I can't find any data sheet on it.
                                    Also can this be tested at all? That's a bit too small for me to remove and replace
                                      pulled out QP811CS between drain and source meter beeps while in diode mode
                                        LOOSE THE BEEP, that is useless and does'nt mean anything. use the ohm setting or diode test and post the resistance number.
                                        QP801CS & QP811CS are shorted drain to source
                                        White stuff is silicone heatsink compound and should be used on the replacement parts.
                                          Oh I thought in diode mode when you get a beep it means it's open and only get 0 Vdc on the meter
                                          Meter in Diode mode:
                                          QP811CS -- D to S = 0.00 vdc; G to S = .14Vdc
                                          QP801CS -- D to S = OL vdc; G to S = OL Vdc
                                          When I touched the gate on QP801CS then I got it to turn on and meter showed 0.00 vdc
                                          Meter in resistance mode:
                                          QP811CS -- D to S = 0.1 ohms; G to S = 149.8 ohms; G to D = 149.8 ohms
                                          Meter Leads reversed -- D to S = 138.3 ohms; G to S = 149.8 ohms; G to D = 138.3 ohms
                                          Meter in Resistance mode:
                                          QP801CS -- D to S = .4M ohms; G to S = OL ohms; G to D = OL ohms
                                          Meter Leads reversed -- D to S = .4 ohms; G to S = OL ohms; G to D = OL ohms
