Here is something that might interest you DC Multifunction LCD Panel Meter
    I found these in an email that I get from MPJA
    https://www.mpja.com/DC-Multifunctio...info/36139+ME/
    You might be interested in this one as well
    https://www.mpja.com/Dcdc-adjustable...info/36146+PS/
    You might also be interested in this one as well
    https://www.mpja.com/Boost-Buck-DC-D...info/36140+PS/
    I have bought one of each to try out for a lithium ion battery charger controller
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Here is something that might interest you DC Multifunction LCD Panel Meter
    a friend has the first meter - he wasnt impressed with the lcd viewing angle.
      In general the LCD displays that have backlights have this problem unless you pay a lot for the display even then you are limited by how far you can see display at angle on the sides or up and down view
      So the real question is how well does it work besides the viewing of the display
      9 PC LCD Monitor
      1 Dell Mother Board
        it does what it says on the box pretty much.
        thing is, if it's on a bench and your above or below it you cant read it well.
        oled is the way to go.
