Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 04-21-2021, 04:30 AM   #1
Patty
City & State: Aberdeen
My Country: Scotland
I'm a: Knowledge Seeker
Default PS4 - Weird BLOD Problem - Still Turns On Sometimes
Hi folks!
I’m new here. And I’m new to the world of electronics and repair. My PS4 suffers from the blue light of death. I have tried the washer method, cleaning it and replacing thermal paste and also replacing the hard drive.
What’s weird about this blue light of death is that it will boot up, but when it restarts or is turned off it won’t turn back on again unless it’s left for a significant amount of time. Usually a few hours to a day or two.
Would this still be an APU problem or is there anything else I could look into checking?
Your help would be greatly appreciated.
Thanks folks!
Patty is offline   Reply With Quote
Old 07-22-2021, 02:41 AM   #2
newbie_unlocker
City & State: northwest uk
My Country: england
Default Re: PS4 - Weird BLOD Problem - Still Turns On Sometimes
blod can be many things I would suggest to reflow all the ram chips as a starting point. the chips are a lot smaller so temp setting should be around 200 degrees and flow each chip for around 90 seconds each one, also use flux, best is kingbo rma flux and mask off any other small components that might be near the ram. let us know how that goes.
newbie_unlocker is offline   Reply With Quote
Old 08-02-2021, 12:48 AM   #3
survivalbloke
City & State: Maryland
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Exactly which PS4 model is this? As newbie_unlocker mentioned, there are a ton of causes for BLOD and it would help to know which version of the console you're running. Launch consoles were most affected by the APU solder connection issue which is very commonly remedied with the washer trick. The newer models like the pro however, don't generally have the same issues.
survivalbloke is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
