Gateway 900G 19" LCD monitor: LVDS cable GLUE?
    Re: Gateway 900G 19" LCD monitor: LVDS cable GLUE?
    Originally posted by eccerr0r View Post
    FUUQ
    Now I know why this thing gets so hot... I thought it was a switching power supply and then I notice a TO220 with
    7812 ***
    printed on it... aaaahhh....
    *** This will give you more heat if loading the hell out of it ***
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Boom!
        Boom!
        Ops not going very good it has seen better days
        How hard would it be to put a buck converter board in place of the lm7812
        Because they also make switch regular that runs a lot cooler and does not require a heat sink unless you run the hell out of it they have voltages from 3.3/5/12 and an adjustable version as well of this type of regular
        Here is a website that sells the 5 volt version of this type of regulator I have used them in the past and they work very well and do not run very hot
        https://www.futurlec.com/Mini_Power.shtml
        Here is the 12 volt version of this type of regulator however they do not offer the single power rail anymore unfortunately but you just make a board using the same exact parts
        https://www.futurlec.com/Mini_Power_Dual_12V.shtml
        Here is the 12 volt version 3 amp version of the same type of regulator
        LM2576HVT-12
        Here is the 5 volt 3 amp version for this type of device
        https://www.futurlec.com/Mini_5V_High_Power.shtml
        I only posted this information for reference purposes
        9 PC LCD Monitor
        1 Dell Mother Board
          Other option is to relocate the 7812 to a different heatsink perhaps, but I just noticed something else...probably have to desolder the diode but I noticed it seemed a little leaky... this would cause some heat...
            Welp, in went some new caps and the monitor is alive again. Posting this so I have a record when I last changed them...again...
            Some Chemicon and Nichicon caps went in this time, and two 470uF 25V caps went in instead of a 1000uF 25V. I think the former might be better as it's more surface area to dissipate heat.
            Now...when will be the next time I repair this monitor...
