Thread Tools | Display Modes |
#1 |
City & State: Athens
My Country: Greece
Line Voltage: 230V 50Hz
I'm a: Knowledge Seeker
![]() I have this monitor, it doesnt power up.
The voltage on the connector CN902 is only 4,5V instead of 19V. With a quick test I see the voltage on pin 6 of transformer T902 is going crazy from 150 to 250V (tested in DC mode). Diodes and Q901 seem ok. Any suggestions? Last edited by Sraros; 01-24-2021 at 07:34 AM.. |
#2 |
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
![]() Whatd dc voltage do you have between the two legs of the large 47uF 450V capacitor
What is the part number on U901
__________________
Willing to help but I'm no expert. Last edited by dick_barton; 01-24-2021 at 07:47 AM.. |
#3 |
My Country: Greece
![]() 300V steady
Q901:SMK0465 U901: AS358M Last edited by Sraros; 01-24-2021 at 08:53 AM.. |
#4 |
My Country: Wales
![]() That voltage appears low considering it's a 450V capacitor.
#5 |
City & State: Sochi
My Country: russia
![]() In this circuit 300v. the norm, there is no PFC here.
#6 |
City & State: Sochi
My Country: russia
![]() U901 cannot be AS358M (LOW POWER DUAL OPERATIONAL AMPLIFIERS).
#7 |
City & State: Sochi
My Country: russia
![]() Here is a diagram that might help you figure it out.
#8 |
My Country: Wales
![]() What voltage do you have across C922
With your meter set to diode mode and the set switched off have you checked D901 and D904 |
#9 |
My Country: Greece
![]() D901 is ok. 339 and infinity. D904 doesnt exist, but whatever, I guess it was just to split the load.
@lotas U901 well, it is AS358M, look at the photo. C922 is jumping from 12,3V to 15,1V! Last edited by Sraros; 01-24-2021 at 05:48 PM.. |
#10 |
City & State: Sochi
My Country: russia
![]() @lotas U901 well, it is AS358M, look at the photo.
AS358M is U801 and U901 is PF6003AG (sot23-6). |
#11 |
My Country: Greece
#12 |
My Country: Wales
![]() I found a reference on the internet that said the PF6003 can be a replacement for LD5532GS
The data sheet for the LD5532GS says that when capacitor C922 voltage reaches 16V then the IC starts to operate and drive the mosfet. This initial voltage to charge C922 comes from the resistor chain R924/925/939/937/926 When the voltage across C922 reaches 16 volts the mosfet is driven and the feedback winding on the transformer T902 maintains the voltage on C922 via R920 & D903 I would check those components especially C922 It also says on page 12 of the pdf that the IC can be turned off if the COMP pin of the LD5532 is taken below 1.5V. The Comp pin would be the FB pin on the PF6003 Last edited by dick_barton; 01-25-2021 at 08:22 AM.. |
#13 |
My Country: Greece
![]() So, I checked with an LCR tester the cap C922 and is ok. ESR 2Ω for 4,7uF 50V.
Also all the diodes seem ok. So I checked on voltage mode as many components as possible. The voltage between ground and C922 is steady -80V (black lead in ground). Everything looks steady in general except the drain, which ofc is attached also to the leg6 of the transformer, and it makes me wonder maybe Q901 is not working right and causing the fault... |
#14 |
City & State: Sochi
My Country: russia
![]() 80 volts is a lot.
The voltage on the C922 must be measured on the capacitor itself, this power supply has different gnd (one in the primary, another in the secondary). |
#15 | |
My Country: Greece
![]() Quote:
![]() I read again also what dick_barton said. Now I understood what you meant and how it works Last edited by Sraros; 01-25-2021 at 03:07 PM.. |
#16 |
My Country: Greece
![]() I swapped the capacitor C922 with a new one and still the same.
The diode D903 is S1M. https://www.vishay.com/docs/88711/s1.pdf Can I replace with a diode 1N4007 for testing? |
#17 |
My Country: Wales
![]() The diode is probably an Schottky diode due to the high frequency of the transformer switching. The 4007 is a general purpose diode not suitable as a replacement.
#18 |
My Country: Wales
![]() Test the diodes (D902, D903 & D905) using your meter in diode mode. Two readings per diode by reversing the leads for the second reading.
Have you checked Q901. Plenty of Youtube videos showing how to. Did you check the resistor network I mentioned since if they have increased in value then the initial VCC voltage for U901 will not be correct. Last edited by dick_barton; 01-26-2021 at 04:19 AM.. |
#19 |
My Country: Greece
![]() I checked the diodes they are all fine.
MOSFET Q901: I followed instructions from youtube When it’s in the PCB: OFF state S-D infinity, charging the gate and then S-D still infinity. But if I take out of the PCB the MOSFET, and charge the gate then S-D: 340 The resistor chain is fine each one of them Last edited by Sraros; 01-26-2021 at 02:39 PM.. |
Thread Tools | |
Display Modes | |
