Hi there,
I've got a Technika LCD 32-270 (aka. M32/57G-GB-FTCU-UK), which is currently stuck in standby. When the power supply is on, it simply lights the red standby LED, and shows no sign of life when I press buttons on the side panel or remote control.
Directly before this happened, the TV picture was replaced by a bright green distorted mess and the sound by loud white noise - this lasted a few seconds before it turned itself off and went to standby. The same thing also happened a few months ago, after which I left it turned off for a number of weeks, and it miraculously started to work again until now!
I've opened it up and had a look at the capacitors - no obvious bulging, but there is some gunk on the positive leg of C7 on the PSU board (see pics). +5VSB measures about 4.9V constantly on my multimeter and +5V about 4.7V, +12V is very low (varying between approx. 0-4V) and +24V is dead. Should I expect all these voltages to be high, even in standby, or are they only turned on if the logic board asks for them? I guess I'm mostly trying to work out if it's the PSU or logic board at fault here.
Any recommendations for my next move?
Thanks in advance!
Dan
Thanks in advance!
Dan
